Hi, I’ve got a GSM-Q2403 which is not making any connection. The SIM card works fine in another modem (Insys GSM Small 2.0). When I put the same SIM into the Wavecom modem, I get:
Apparently very old hardware, even though we just purchased it from RS components last week:
LED is solid red, the manual indicates this means “Standby (registered to the net)”. It was previously blinking, not sure exactly when it went solid. the modem is apparently not in a power down mode:
The Modem is not in a sleep mode
4.13.3 Defined values :
<pas> 0 ready (allow commands from TA/TE)
1 unavailable (does not allow cmds)
2 unknown
3 ringing (ringer is active)
4 call in progress
5 asleep (low functionality)
The unit is apparently not registered on the network:
6.3.3 Defined values :
<mode> 0: Disable network registration unsolicited result code (default)
1: Enable network registration code result code +CREG : <stat>
2: Enable network registration and location information
unsolicited result code +CREG: <stat>,<lac>,<ci> if there is a change
of the network cell.
<stat> 0 : not registered, ME is not currently searching a new operator
1 : registered, home network
2 : not registered, ME currently searching a new operator to register to
3 : registration denied
4 : unknown
5 : registered, roaming
And so it can’t get a signal strength:
Windows Modem connection manager cannot make a connection through this modem, even though the exact settings (unchanged other than swapping the modem) worked with the Inysy modem:
11-23-2017 17:38:25.750 - File: C:\Windows\system32\tapisrv.dll, Version 6.1.7601
11-23-2017 17:38:25.751 - File: C:\Windows\system32\unimdm.tsp, Version 6.1.7601
11-23-2017 17:38:25.751 - File: C:\Windows\system32\unimdmat.dll, Version 6.1.7601
11-23-2017 17:38:25.752 - File: C:\Windows\system32\uniplat.dll, Version 6.1.7600
11-23-2017 17:38:25.753 - File: C:\Windows\system32\drivers\modem.sys, Version 6.1.7600
11-23-2017 17:38:25.753 - File: C:\Windows\system32\modemui.dll, Version 6.1.7600
11-23-2017 17:38:25.755 - File: C:\Windows\system32\mdminst.dll, Version 6.1.7600
11-23-2017 17:38:25.755 - Modem type: Standard 33600 bps Modem
11-23-2017 17:38:25.755 - Modem inf path: mdmgen.inf
11-23-2017 17:38:25.755 - Modem inf section: Gen336
11-23-2017 17:38:25.755 - Matching hardware ID: mdmgen336
11-23-2017 17:38:25.756 - Opening Modem
11-23-2017 17:38:25.757 - 115200,8,N,1, ctsfl=1, rtsctl=2
11-23-2017 17:38:25.757 - Initializing modem.
11-23-2017 17:38:25.757 - DSR is low while initializing the modem. Verify modem is turned on.
11-23-2017 17:38:25.761 - Recv: <00>
11-23-2017 17:38:25.762 - Unknown Response
11-23-2017 17:38:25.829 - TSP(0000): Making Call
11-23-2017 17:38:25.962 - Send: AT<cr>
11-23-2017 17:38:25.963 - Recv: AT<cr>
11-23-2017 17:38:25.963 - Command Echo
11-23-2017 17:38:25.967 - Recv: <cr><lf>OK<cr><lf>
11-23-2017 17:38:25.967 - Interpreted response: OK
11-23-2017 17:38:25.977 - Send: ATE0V1<cr>
11-23-2017 17:38:25.979 - Recv: ATE0V1<cr>
11-23-2017 17:38:25.979 - Command Echo
11-23-2017 17:38:25.983 - Recv: <cr><lf>OK<cr><lf>
11-23-2017 17:38:25.983 - Interpreted response: OK
11-23-2017 17:38:25.993 - Send: AT<cr>
11-23-2017 17:38:25.997 - Recv: <cr><lf>OK<cr><lf>
11-23-2017 17:38:25.997 - Interpreted response: OK
11-23-2017 17:38:25.998 - Waiting for a call.
11-23-2017 17:38:26.008 - Send: ATS0=0<cr>
11-23-2017 17:38:26.012 - Recv: <cr><lf>OK<cr><lf>
11-23-2017 17:38:26.012 - Interpreted response: OK
11-23-2017 17:38:26.013 - 115200,8,N,1, ctsfl=1, rtsctl=2
11-23-2017 17:38:26.013 - Initializing modem.
11-23-2017 17:38:26.013 - DSR is low while initializing the modem. Verify modem is turned on.
11-23-2017 17:38:26.023 - Send: AT<cr>
11-23-2017 17:38:26.027 - Recv: <cr><lf>OK<cr><lf>
11-23-2017 17:38:26.027 - Interpreted response: OK
11-23-2017 17:38:26.037 - Send: ATE0V1<cr>
11-23-2017 17:38:26.043 - Recv: <cr><lf>OK<cr><lf>
11-23-2017 17:38:26.043 - Interpreted response: OK
11-23-2017 17:38:26.053 - Send: AT<cr>
11-23-2017 17:38:26.057 - Recv: <cr><lf>OK<cr><lf>
11-23-2017 17:38:26.058 - Interpreted response: OK
11-23-2017 17:38:26.058 - Dialing.
11-23-2017 17:38:26.058 - TSP Completing Async Operation(0x00010164) Status 0x00000000
11-23-2017 17:38:26.058 - TSP(0000): LINEEVENT: LINECALLSTATE_DIALING
11-23-2017 17:38:26.058 - TSP(0000): LINEEVENT: LINECALLSTATE_PROCEEDING
11-23-2017 17:38:26.068 - Send: ATDT*##***##<cr>
11-23-2017 17:38:26.080 - Recv: <cr>
11-23-2017 17:38:26.080 - Interpreted response: Informative
11-23-2017 17:38:26.080 - Recv: <lf>
11-23-2017 17:38:26.081 - Recv: CONNECT
11-23-2017 17:38:26.081 - Interpreted response: Connect
11-23-2017 17:38:26.081 - Receive Connect but CD was low, Waiting for signal to go high
11-23-2017 17:38:26.101 - CD has been raised
11-23-2017 17:38:26.101 - Connection established at 115200bps.
11-23-2017 17:38:26.101 - Error-control off or unknown.
11-23-2017 17:38:26.101 - Data compression off or unknown.
11-23-2017 17:38:26.101 - TSP(0000): LINEEVENT: LINECALLSTATE_CONNECTED
11-23-2017 17:38:29.366 - CD dropped--Remote modem hung up. ModemStatus=00000010
11-23-2017 17:38:29.366 - While processing CD dropping, CTS or DSR was found low.
11-23-2017 17:38:29.366 - TSP(0000): LINEEVENT: LINECALLSTATE_DISCONNECTED(0x1)
11-23-2017 17:38:29.367 - TSP(0000): Dropping Call
11-23-2017 17:38:29.367 - Hanging up the modem.
11-23-2017 17:38:29.372 - Recv: <cr><lf>ERROR<cr><lf>
11-23-2017 17:38:29.372 - Interpreted response: Error
11-23-2017 17:38:29.373 - Recv: <cr><lf>NO CARRIER<cr><lf>
11-23-2017 17:38:29.373 - Interpreted response: No Carrier
11-23-2017 17:38:29.382 - Send: ATH<cr>
11-23-2017 17:38:29.387 - Recv: <cr><lf>OK<cr><lf>
11-23-2017 17:38:29.387 - Interpreted response: OK
11-23-2017 17:38:29.387 - 115200,8,N,1, ctsfl=1, rtsctl=2
11-23-2017 17:38:29.387 - Initializing modem.
11-23-2017 17:38:29.387 - DSR is low while initializing the modem. Verify modem is turned on.
11-23-2017 17:38:29.397 - Send: AT<cr>
11-23-2017 17:38:29.401 - Recv: <cr><lf>OK<cr><lf>
11-23-2017 17:38:29.401 - Interpreted response: OK
11-23-2017 17:38:29.411 - Send: ATE0V1<cr>
11-23-2017 17:38:29.416 - Recv: <cr><lf>OK<cr><lf>
11-23-2017 17:38:29.416 - Interpreted response: OK
11-23-2017 17:38:29.426 - Send: AT<cr>
11-23-2017 17:38:29.430 - Recv: <cr><lf>OK<cr><lf>
11-23-2017 17:38:29.430 - Interpreted response: OK
11-23-2017 17:38:29.430 - Waiting for a call.
11-23-2017 17:38:29.440 - Send: ATS0=0<cr>
11-23-2017 17:38:29.444 - Recv: <cr><lf>OK<cr><lf>
11-23-2017 17:38:29.444 - Interpreted response: OK
11-23-2017 17:38:29.444 - Detected DSR drop while monitoring for calls. Likely modem turned off.
11-23-2017 17:38:29.444 - TSP(0000): LINEEVENT: LINECALLSTATE_IDLE
11-23-2017 17:38:29.444 - TSP Completing Async Operation(0x00010264) Status 0x00000000
11-23-2017 17:38:29.445 - TSP(0000): Closing Call
11-23-2017 17:38:29.454 - Session Statistics:
11-23-2017 17:38:29.454 - Reads : 24 bytes
11-23-2017 17:38:29.454 - Writes: 20 bytes
Any clues on how to get this modem to work with Windows?
I have a private APN, but that shouldn’t have any effect at this stage of connection. The Insys modem can connect OK, and I can ping another device in the same private pool.
Thanks for your help,
Cheers.
