My first post on this forum so greetings to everyone.
We’ve recently bought ES450 Airlink router as a fallback for our Lantronix. I’m trying to set some initial configuration however I am not able to connect to the ACE Manager via web. I’m connected through ethernet cable and I’ve set the proper address on my laptop (192.168.13.0/24 subnet). However the http://192.168.13.31:9191 is not responding. I can ping the device and access 192.168.13.31:8088 (which says Not found). I am able to enter the recovery mode and fetch the logs if that could help.
The Network indicator flashing Red/Amber means the gateway is unable to locate the required radio module firmware. You must upgrade the radio module firmware for the gateway.
