Using the DWLwin 4.1.6.6 and the dongle key I downloaded the R71a01-cus-wmp-01.wpk file into the flash of the WMP100. When the download process is finished, the DWLwin confirmed that everything was ok. Then I restart the WMP100 and the first thing that it sends is the +WDWL string.
if i send the “AT” command the WMP100 responds “OK”. If I send the “AT+WDWL?” command the WMP100 responds “+WDWL: V08b03”. To any other command the WMP100 responds “ERROR”.
I had the exact same problem with WMP100 using DWLWin V 4.1.6.6, except I was downloading R71-cus-wmp-02.wpk.
Having wasted several hours scratching my head and cursing Wavecom I came across the answer on this bulleting board and now works fine. I’m not sure if the problem lies in the WMP100 or in DWLWIN, but please Wavecom - you need to fix this !
I think I have a similar problem:
If i send the “AT” command the WMP100 responds “OK”. If I send the “AT+WDWL?” command the WMP100 responds “+WDWL: V08b0k”. To any other command the WMP100 responds “ERROR”.
I get V08B0K instead of V08B03.
I’ve tried solution proposed by ToF but it doesn’t work for me!
Thanks awneil,
I have asked to my distributor and said to me to download firmaware again. I’ve tried it several times and it doesn’t work! because of this I ask to you to know if someone have had a similar error.
I don’t know whats happening because it worked fine before.
I think I’m missing something during download process.
Other devices that are in a board developed by us can be programmed without any problem but Dev Kit doesn’t seem to work.
Also, I’ve tried putting other wmp100 chip provided with Dev Kit an download firmaware to it and have the same behaviour.
It’s strange behaviour becuse process ends with succesfull state.
I’m going to ask to my distributor to change Dev. Kit.
