EM9191 for 5G Sub-6G Application- Can be used with 2 antennas only? Or necessary to have all 4 antennas?
From the datasheet, it looks like if have no need to use n41 band and GNSS, then for 5G Sub-6GHz application can just use Main and Aux antenna, and leave the MIMO1 & MIMO2 unconnected?
Hi henrylee ,
Yes, it is.
Yes, the unit will be functional with just a single antenna if you want, we have customers who only want uplink, don’t use GNSS or N41 and so only have a single antenna. All you do is restrict the units ability to perform and you will also have issues with carrier approvals as they require multiple antennas to pass their tests.
