I can not get work at china mobile N41 5G network . modem only registeredat China mobile lte network.I can confirm sim card work at 5G with quectel RM500Q and Simcom8200 at china mobile SA network at same time and sameplace.
I can work at 5G NSA at china telecom N78 with EM9190. I want to force EM9190 to NSA for china mobile ,is it possible?
my current firmware version:SWIX55C_01.07.08.00 000000 jenkins 2020/11/16 10:11:33
I connect 4 antenna to test,
I have fully work at NSA N78 ,but never work at SA at N41
at!gstatus?
!GSTATUS:
Current Time: 132 Temperature: 41
Reset Counter: 1 Mode: ONLINE
System mode: ENDC PS state: Attached
LTE band: B3 LTE bw: 20 MHz
LTE Rx chan: 1850 LTE Tx chan: 19850
RRC state: RRC Connected
IMS reg state: REGISTERED IMS mode: Normal
IMS Srv State: FULL SMS,NO VoIP
PCC RxM RSSI: -50 PCC RxM RSRP: -77
PCC RxD RSSI: — PCC RxD RSRP: —
PCC RxM1 RSSI: — PCC RxM1 RSRP: —
PCC RxD1 RSSI: — PCC RxD1 RSRP: —
Tx Power: 5 TAC: 4513 (17683)
RSRQ (dB): -7.2 Cell ID: 04542e32 (72625714)
SINR (dB): 21.2
NR5G band: n78 NR5G bw: 100 MHz
NR5G Rx chan: 630000 NR5G Tx chan: 630000
NR5G RSRP (dBm): -103 NR5G RSRQ (dB): -13
NR5G SINR (dB): 8.0
If you want to test n41 SA, please try below.
- ensure 4 antennas are used and it can support n41
- issue AT command at!selrat=05 and then at!reset
- show me the result of AT!band=?
before I change at!selrat=05 ,I at!gstatus?
!GSTATUS:
Current Time: 113 Temperature: 30
LTE band: No band LTE bw: 1.4 MHz
LTE Rx chan: 4294967295 LTE Tx chan: 4294967295
EMM state: Registered PLMN Search
RRC state: RRC Idle
PCC RxM RSSI: — PCC RxM RSRP: —
Tx Power: – TAC: ffff (65535)
RSRQ (dB): 0.0 Cell ID: ffffffff (4294967295)
SINR (dB): 0
NR5G band: — NR5G bw: —
NR5G Rx chan: — NR5G Tx chan: —
NR5G RSRP (dBm): — NR5G RSRQ (dB): —
NR5G SINR (dB): —
**after I at!selrat=05 and then at!reset **
at!band=?
Index, Name
00, All bands
01, Europe 3G
02, North America 3G
06, Europe
07, North America
08, WCDMA ALL
09, LTE ALL
0C, NR5G ALL
but modem can not get internet
at!gstatus?
at!gstatus?
!GSTATUS:
Current Time: 292 Temperature: 34
System mode: NR5G PS state: Not attached
IMS reg state: NOT REGISTERED IMS mode: Normal
IMS Srv State: UNKNOWN SMS,UNKNOWN VoIP
Tx Power: 0 TAC: d06404
Connectivity Mode: SA
Cell ID: 235
NR5G band: n78 Carrier Index: 0
NR5G dl bw: 20 MHz NR5G ul bw: Unknown
NR5G Rx chan: 627336 NR5G Tx chan: 0
NR5G dl MIMO: 4 NR5G ul MIMO: 0
NR5G(sub6) RxM RSSI (dBm): -59.3 NR5G(sub6) RxD RSSI (dBm): -63.9
NR5G(sub6) RxM1 RSSI (dBm): — NR5G(sub6) RxD1 RSSI (dBm): —
NR5G RSRP (dBm): -96 NR5G RSRQ (dB): -11
NR5G SINR (dB): 17.5
Btw. My sim card carrier is China Mobile, have not N78 network.
