In my testing, EM9191 does not connect to 5G NSA on Verizon network. If I put the Verizon sim card in an iPhone, the iPhone connects to 5G band 5 along with LTE.
Is there any command or requirement for EM9191 to connect 5G bands on Verizon network?
By the way, with a T-Mobile sim card, EM9191 can connect to 5G on the T-Mobile network.
AT!IMPREF?
current fw version: 03.09.11.00
current carrier name: VERIZON
current config name: VERIZON_030.046_001
AT!BAND?
Index, Name
00, All bands
AT+COPS?
+COPS: 0,0,"Verizon ",13
AT!SELRAT=0F
at!gstatus?
!GSTATUS:
Current Time: 2137 Temperature: 35
Thermal Mitigation Level: 0
Reset Counter: 2 Mode: ONLINE
LTE band: B13 LTE bw: 10 MHz
LTE Rx chan: 5230 LTE Tx chan: 23230
LTE SCC1 state:INACTIVE LTE SCC1 band: B2
LTE SCC1 bw : 20 MHz LTE SCC1 Rx chan: 1100
LTE SCC1 UL Configured: FALSE LTE SCC1 Tx chan: 0
LTE SCC2 state:INACTIVE LTE SCC2 band: B48
LTE SCC2 bw : 20 MHz LTE SCC2 Rx chan: 55943
LTE SCC2 UL Configured: FALSE LTE SCC2 Tx chan: 0
LTE SCC3 state:INACTIVE LTE SCC3 band: B48
LTE SCC3 bw : 20 MHz LTE SCC3 Rx chan: 56141
LTE SCC3 UL Configured: FALSE LTE SCC3 Tx chan: 0
LTE SCC4 state:INACTIVE LTE SCC4 band: B66
LTE SCC4 bw : 20 MHz LTE SCC4 Rx chan: 0
LTE SCC4 UL Configured: FALSE LTE SCC4 Tx chan: 0
RRC state: RRC Connected
IMS reg state: REGISTERED IMS mode: Normal
IMS Srv State: FULL SMS,UNKNOWN VoIP
PCC RxM RSSI: -63 PCC RxM RSRP: -95
PCC RxD RSSI: -73 PCC RxD RSRP: -110
SCC1 RxM RSSI: -84 SCC1 RxM RSRP: -115
SCC1 RxD RSSI: -86 SCC1 RxD RSRP: -116
SCC1 RxM1 RSSI: --- SCC1 RxM1 RSRP: ---
SCC1 RxD1 RSSI: --- SCC1 RxD1 RSRP: ---
SCC2 RxM RSSI: -96 SCC2 RxM RSRP: -124
SCC2 RxD RSSI: -91 SCC2 RxD RSRP: -119
SCC2 RxM1 RSSI: --- SCC2 RxM1 RSRP: ---
SCC2 RxD1 RSSI: --- SCC2 RxD1 RSRP: ---
SCC3 RxM RSSI: -95 SCC3 RxM RSRP: -123
SCC3 RxD RSSI: -90 SCC3 RxD RSRP: -121
SCC3 RxM1 RSSI: --- SCC3 RxM1 RSRP: ---
SCC3 RxD1 RSSI: --- SCC3 RxD1 RSRP: ---
SCC4 RxM RSSI: -87 SCC4 RxM RSRP: -115
SCC4 RxD RSSI: -89 SCC4 RxD RSRP: -117
SCC4 RxM1 RSSI: --- SCC4 RxM1 RSRP: ---
SCC4 RxD1 RSSI: --- SCC4 RxD1 RSRP: ---
PCC Tx Power: --- TAC: xx (xx)
SCC1 Tx Power: ---
SCC2 Tx Power: ---
SCC3 Tx Power: ---
SCC4 Tx Power: ---
RSRQ (dB): -13.6 Cell ID: xx (xx)
SINR (dB): 6.6
NR5G band: --- NR5G bw: ---
NR5G Tx Power: --- NR5G Tx chan: ---
NR5G Rx chan: --- NR5G RSRP (dBm): ---
NR5G RSRQ (dB): --- NR5G SINR (dB): ---
