Hi, I am having an issue getting my EM9191 module to connect to the Verizon 5G network. It is connected over LTE, but for some reason it won’t connect to 5G. I’ve updated the firmware to “03.10.11.00” and the current config is “VERIZON_030.067_000”. I’m set up in an upstairs bedroom where other devices are able to connect to Verizon 5G, so I don’t think physical area is a factor. I’ve attached some screenshots that will hopefully be helpful. I am stumped on what to do at this point and would appreciate some help.
have you checked “AT!SELRAT?” and “AT!BAND?” to see if there is abnormal setting?
BTW, you need to keep generating some data traffic, otherwise it would stay in LTE mode.
I appreciate the quick reply. I’ve attached a screenshot of the output of AT!SELRAT? and AT!BAND?, but it looks okay to me. Also, keeping constant data is a good to know. However, I’ve started doing that and am still seeing the same thing.
I switched from a Verizon sim card to the T-Mobile one in my phone and was immediately able to connect to the 5G network. Same physical location. Here is the result of the !GSTATUS command. Could a lack of signal be the reason why it’s preferring 4G over 5G in the case of Verizon?
