Hi, I think I have identified the best family of modules integrated into your EM Series family but there are too many models. 5G RedCap - 5G mmWave and Sub-6. My needs are:
For USA band 48 (4G) & N48 (5G), For Canada band 77/78. USA Frequency 3550-3700Mhz. Of course also operational and functioning in Italy, my region
Can you suggest me the most appropriate module code??
Thank you for your suggestion.
Yes, may be the last and best model of the EM family ?? I see EM9291 & EM9293 they seem very closed with characteristics, could there be a valid reason to choose the EM9291 in the place of EM9293??? maybe just the price??
I found only EM9293_1105177 (SDX65 M.2 5G NR SUB6 + GNSS) Available on Digikey
EM9291_1105271 is not available…
just now I managed to find the datasheet of the EM92XX family, they seem quite similar, I will check the differences. However, if I have to rely on commercial availability I could go directly to the larger EM9293, ?? the cost is similar. I get the antenna and adapt it to my application, it’s not a problem.
I guess the EM9293 is slightly better?? if I have no other needs and I find him more available could it be better??
The bands it covers and the providers are the same if I’m not mistaken??
Is there a development kit?? should I contact Sierra sales??
Ok So the EM9293 it’s a little bit better, at an approximately Equivalent cost for my applications I could easily choose it??
Thank you for the evaluation Kit, i try to ask at Sierra sales when they answer to me.
Last question; we need an Ethernet connection versus the our device, there is commercial adaptor or equivalent to do this? and connect with EM9293 module ??
Yes, i see that there is a PCIe Interface connector and an USB Interface,
But i need an PCIe or USB To Ethernet converter (My device have only Ethernet)
It seems like there are similar PCI to Ethernet converters on the market?? for This 5G module or am I wrong??? could it work??
