I am trying to update our EM7565 card to the latest firmware, but it seems the updater wont find or recognize the card:
When I try with the FDT-Tool, the device is found and the flashing seems to be working, but at the end the firmware download fails:
FDT version: 2.0.2012.0
Awaiting suitable port or adapter ...
Switching to boot & hold mode ...
Disabling selective suspend ...
Awaiting port removal ...
Awaiting download port ...
Switching to streaming mode ...
Downloading images ...
Writing image C:\Users\Eigenaar\Desktop\Sierra_new\2022\FDTtoll\Bin\x64\release\SWI9X50C_01.14.02.00
.cwe \
Flashing image \
Enabling selective suspend ...
Awaiting adapter ...
Firmware download failed.
Primary error code: 14 - No MBN adapter available.
Secondary error code: 0 - Not applicable.
Device error code: 0x0 - Unknown device error code.
Current:
Firmware:
ImageId:
BuildId:
Configuration:
ImageId:
BuildId:
Final images information:
Current:
Firmware:
ImageId:
BuildId:
Configuration:
ImageId:
BuildId:
OEM PRI:
IMEI:
Total time elapsed: 371516 ms.
Time to switch to boot mode: 9734 ms.
Images downloaded:
Image ID: ?_?
Build ID: 01.14.02.00_?
write time: 15912 ms
additional flash time: 95847 ms
Time to reset to application mode: -1 ms.
Press Enter to continue ...
This is the current situation on the device:
AT!IMAGE?
FW 1 GOOD 1 0 0 ?_? 01.05.01.00_?
FW 2 GOOD 2 0 0 ?_? 01.07.02.00_?
FW 3 GOOD 3 0 0 ?_? 01.09.04.00_?
FW 4 EMPTY 0 0 0
Max FW images: 4
Active FW image is at slot 3
PRI FF GOOD 0 0 0 002.019_000 01.09.04.00_GENERIC
Max PRI images: 50
AT!IMPREF?
!IMPREF:
preferred fw version: 01.09.04.00
preferred config name: GENERIC_002.019_000
preferred subpri index: 000
current fw version: 01.09.04.00
current carrier name: GENERIC
current config name: GENERIC_002.019_000
current subpri index: 000
The OS is Win7 64bit Pro, the latest Sierra drivers are installed and working, the modem, mbim, serial DM and serial NMEA ports are present, and the modem AT interface also works.
An interesting thing is that Skylight is also not detecting the card.
Any ideas why can this be?
