Updating EM7455 in Windows 10
Hi everybody,
I’m having a hell of a time trying to update the firmware of my EM7455 on my Dell Latitude 5490. Device Manager shows it as a DW5811e Snapdrgon X7 LTE.
I’m trying to use my Google Fi Data-only SIM.
It only shows “T-Mobile” and does not register properly. When I run either of the generic FW packages found here: https://source.sierrawireless.com/resources/airprime/minicard/74xx/airprime-em_mc74xx-approved-fw-packages/
It gives me this output:
C:\Drivers\Sierra>fdt2.exe -d g5k -ignswto -f SWI9X30C_02.30.01.01.cwe SWI9X30C_02.30.01.01_GENERIC_002.045_001.nvu
FDT version: 1.0.1702.1
Awaiting adapter …
Setting images preference …
Resetting …
Awaiting download port …
Enabling selective suspend …
Firmware download failed.
Primary error code: 82 - Failed in checking modem mode.
Secondary error code: 5 - Neither NDIS adapter nor serial port is available.
Device error code: 0x0 - Unknown device error code.
Current:
Firmware:
ImageId: 002.025_000
BuildId: 02.24.05.06_GENERIC
Configuration:
Final images information:
Current:
Firmware:
ImageId:
BuildId:
Configuration:
ImageId:
BuildId:
OEM PRI:
IMEI:
Total time elapsed: 38031 ms.
Time to switch to boot mode: -1 ms.
Images downloaded:
Press Enter to continue …
@jenova314,
Hi Jeff,
I think you did install Sierra driver package.
Could you try this,
  1. modify registry key “HKEY_LOCAL_MACHINE\SOFTWARE\Sierra Wireless Inc\Firmware\GENERIC” to “002.045_001”.
  2. confirm the firmware exist in the folder specified in registry key “HKEY_LOCAL_MACHINE\SOFTWARE\Sierra Wireless Inc\QDL\FirmwareLocation”. If not, you may need copy the .cwe and .nvu file to that folder.
  3. restart computer.
after step 3, see whether firmware upgrade happen. if not. let me know. I may need you capture some logs.
@wzhang
Hello, I confirmed 1), but did not even find the registry key in 2). Should I:
  • Restart, and then run the upgrade tool again, OR
  • Create the registry key manually?
Thanks!
@jenova314
Try restart the computer first.
@wzhang
Just tried it tonight. Exact same output :frowning:
The registry key FirmwareLocation is also still non-existent.
@jenova314 Seems your driver package does not include any firmware. Can you help to setup TeamViewer session so that I could take a look remotely?
Before that, let me know where is your fdt2.exe and .cwe .nvu firmware located.
@jenova314 Did you manage to install the latest firmware? please share how?
Anish
hi all,
i am facing this same issue, please assist
What interface do you see in device manager?
what is the return of the followings?
ATi3
at!entercnd=“A710”
at!usbcomp?
at!usbcomp=?
