Hello there
I need a bit help
I have EM7565 with pretty old FW
Model: EM7565-9
Revision: SWI9X50C_00.06.02.00 f50f0a jenkins 2017/08/25 05:33:58
IMEI: 001027009999999
IMEI SV: 1
FSN: XK734688680306
+GCAP: +CGSM
State: Online
LPM voters - Temp:0, Volt:0, User:0, W_DISABLE:0, IMSWITCH:0, BIOS:0, LWM2M:0, OMADM:0, FOTA:0, RFCAL:0
LPM persistence - None
Modem works, but i want to upgrage FW
I have an error after flashing:
FDT version: 1.0.1902.1
Awaiting adapter ...
Setting images preference ...
Resetting ...
Awaiting download port ...
Switching to streaming mode ...
Downloading images ...
Writing image |
Flashing image /
Enabling selective suspend ...
Firmware download failed.
Primary error code: 77 - Failed in streaming download stage.
Secondary error code: 68 - Received incorrect response.
Device error code: 0x80 - Invalid image type.
Current:
Firmware:
ImageId:
BuildId: 00.06.02.00_
Configuration:
ImageId:
Final images information:
Current:
Firmware:
ImageId:
BuildId:
Configuration:
ImageId:
BuildId:
OEM PRI:
IMEI:
Total time elapsed: 38672 ms.
Time to switch to boot mode: 25968 ms.
Images downloaded:
Image ID: ?_?
Build ID: 01.14.02.00_?
failed
Time to reset to application mode: -1 ms.
Press Enter to continue ...
FDT version: 2.0.2012.0
Awaiting suitable port or adapter ...
Switching to boot & hold mode ...
Disabling selective suspend ...
Awaiting DM port ...
Awaiting port removal ...
Writing image C:\Users\Ozzy\Desktop\release\SWI9X50C_01.14.02.00.cwe \
Flashing image |
Current:
Firmware:
ImageId:
Configuration:
ImageId:
Current:
Firmware:
ImageId:
BuildId:
Configuration:
ImageId:
BuildId:
OEM PRI:
IMEI:
Total time elapsed: 27250 ms.
Time to switch to boot mode: 12172 ms.
Images downloaded:
Image ID: ?_?
failed
I have tested like 6 FW, all have the same error
Any fix of that?
I think that need to try to find another pretty old FW, like 00.XX.XX.XX, i have found only 01.XX.XX.XX FW
Thanks for answer
