EM7565 problem after firmware update failure
It looks like I bricked this EM7565 card after a failed attempt to update the firmware, now only one USB interface is present and it’s not an AT interface:
dmesg:
[ 55.262614] usb 1-4.2: new high-speed USB device number 8 using xhci_hcd
[ 55.349384] usb 1-4.2: New USB device found, idVendor=1199, idProduct=9090
[ 55.349389] usb 1-4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 55.349392] usb 1-4.2: Product: QUSB__BULK
[ 55.349395] usb 1-4.2: Manufacturer: Sierra Wireless, Incorporated
[ 55.349398] usb 1-4.2: SerialNumber: UF80168511030634
[ 55.393491] usbcore: registered new interface driver qcserial
[ 55.393571] usbserial: USB Serial support registered for Qualcomm USB modem
[ 55.393627] qcserial 1-4.2:1.0: Qualcomm USB modem converter detected
[ 55.394343] usb 1-4.2: Qualcomm USB modem converter now attached to ttyUSB0
lsusb
Bus 002 Device 003: ID 0451:8140 Texas Instruments, Inc. TUSB8041 4-Port Hub
Bus 002 Device 002: ID 0451:8140 Texas Instruments, Inc. TUSB8041 4-Port Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 008: ID 1199:9090 Sierra Wireless, Inc.
Bus 001 Device 005: ID 0451:8142 Texas Instruments, Inc. TUSB8041 4-Port Hub
Bus 001 Device 007: ID 1976:1307 Chipsbrand Microelectronics (HK) Co., Ltd.
Bus 001 Device 006: ID 045e:0745 Microsoft Corp. Nano Transceiver v1.0 for Bluetooth
Bus 001 Device 003: ID 0451:8142 Texas Instruments, Inc. TUSB8041 4-Port Hub
Bus 001 Device 004: ID 0557:2419 ATEN International Co., Ltd
Bus 001 Device 002: ID 0557:7000 ATEN International Co., Ltd Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
|__ Port 3: Dev 2, If 0, Class=Hub, Driver=hub/4p, 5000M
|__ Port 4: Dev 3, If 0, Class=Hub, Driver=hub/4p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 1: Dev 4, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 3: Dev 3, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 6, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 1: Dev 6, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 1: Dev 6, If 2, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 7, If 0, Class=Mass Storage, Driver=usb-storage, 480M
|__ Port 4: Dev 5, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 2: Dev 8, If 0, Class=Vendor Specific Class, Driver=qcserial, 480M
ls /dev | grep USB
ttyUSB0
Has anyone encountered this problem?, how do we recover from this?
Thank you
This is the bootloader. You should be able to fix the issue by rerunning the firmware upgrade. Possibly with another firmware version, depending on why it failed initially. But I would have tried the same version first.
Thank you dl5162, the firmware downloading software is finding the device in an unexpected state and stops immediately:
[ 1953.218582] usb 5-1.2: new full-speed USB device number 4 using uhci_hcd
[ 1953.401637] usb 5-1.2: New USB device found, idVendor=1199, idProduct=9090
[ 1953.401640] usb 5-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1953.401642] usb 5-1.2: Product: QUSB__BULK
[ 1953.401644] usb 5-1.2: Manufacturer: Sierra Wireless, Incorporated
[ 1953.401646] usb 5-1.2: SerialNumber: UF80168511030634
[ 1953.407672] GobiSerial 5-1.2:1.0: GobiSerial converter detected
[ 1953.407761] usb 5-1.2: GobiSerial converter now attached to ttyUSB0
./fwdwl-litehostx86_64 -d /dev/ttyUSB0 --fwpath /home/Downloads/SWI9X50C_01.07.02.00_ATT_002.008_004
litefw version :lite-fwSLQS04.00.19
INFO: QDL Port : /dev/ttyUSB0
INFO: Device Path: /dev/qcqmi0
INFO: FW Path : /home/mhizem/Downloads/SWI9X50C_01.07.02.00_ATT_002.008_004
Package Info:
Carrier :ATT
FW Version :01.07.02.00
Model ID :SWI9X50C
Package ID :004
PRI Version:002.008
SKU :9999999
GetDeviceMode: ERROR! Unknown modem state
Modem not in correct state
Exiting Application!!!
Tried -i -1 & -u -1 options with the same result (also with any other possible option)
I’m using Gobi package S2.36N2.56, It could be failing because of /dev/qcqmi0 not being mapped.
Any other ideas of potentially another package that could work only on /dev/ttyUSBx?
Thank you
Hello there!
Do you have a solution of this problem? I have EM7565 that stuck at QALoder port too :C
you need to use MBPL version upper than R27 to run the lite-fw-download to upgrade module in boot and hold mode
sudo ./bin/fwdwl-litehostx86_64 -c QMI -m 4 -d /dev/ttyUSB0 -f /home/jordan/Downloads/FW_EM74x1/SWI9X50C_01.14.03.00_GENERIC_002.036_010/
I’m using that command:
ubuntu-mate@ubuntu-mate:~$ ./fwdwl-litehostx86_64 -d /dev/$devpath --modelfamily 4 --logfile "fwdwl-lite-$devpath.log" -e 1 --fwpath "./swi_fw0105/"
litefw version :lite-fwSLQS04.00.15
INFO: FW  Path  : ./swi_fw0105/
Package Info:
Carrier    :GENERIC
FW Version :01.05.01.00
Model ID   :SWI9X50C
Package ID :000
PRI Version:001.028
SKU        :9999999
From this post:
I’m not Linux user (Windows 99,9% time), how i need to edit this command?
My modem starts with QDLoader port vid 1199:9090 VID/PID
How to check what is my version is and how to install the new one?
you are using the old Gobi SDK.
To download new MBPL SDK, you can go to here:
https://source.sierrawireless.com/resources/airprime/software/mbpl/mbpl-software-latest/#sthash.qzsmPuwe.dpbs
