The URL from the Homepage seems different as in the Code. But not sure.
Someone else on Github has the same Problem.
But still no solution for it.
Probably you need use the MBPL usb driver and fwdwl tool to download firmware in linux
https://source.sierrawireless.com/resources/airprime/software/mbpl/mbpl-software-latest/
ohh thats out of my range now
Is it possible to rewrite the Code, that he uses the File direct from the PC?
Not to download it first?
What do yoy mean actually?
My Coding Skills are 0 so i cant do that.
The Autoflash 7455.SH code is written so that it first wants to download the firmware from the sierra site, is it possible to modify the code so that it uses the firmware directly from the folder?
you can try to delete line 538:
[[ $download_modem_firmware_trigger ]] && download_modem_firmware
Thanks so far… now hes flashing a different firmware SWI9X30C_02.39.00.00… this one is even not in the folder
then is the download ok?
hes downloading a different version, but this one is not in the folder.
now i tried it again but now I have an error unknown firmware image file
not even know where is the location of your file…
its under home/alptech/Downloads
then why did it show unknown FW image?
still trying to figure it out
no idea, you might need to use the official fwdwl tool
Many Thanks, I found a solution, had to change Line 308 “Release 23” to “045”
Then the Download works again for FW SWI9X30C_02.30.01.01 and I can Flash the Modems.
