Rma
                    September 18, 2023, 12:49pm
                  1
Hello Hello,
i try to flash my new Batch of 100x EM7455 but it doesnt work. I tried every Single Version but no succes.
For every help im very greatful
Thank you
                jyijyi
                    September 18, 2023,  1:08pm
                  2
              how about running the “AT!BOOTHOLD” first?
                Rma
                    September 18, 2023,  1:23pm
                  3
              Hello, thank you. But can you explain it a little bit more?
                jyijyi
                    September 18, 2023,  1:27pm
                  4
              Do you have modem port in device manager for communicating by AT command?
                Rma
                    September 18, 2023,  1:28pm
                  5
              No i dont have it in the Device Manager.
                jyijyi
                    September 18, 2023,  1:33pm
                  6
              You can see here to get back the modem port:
    you can open Configuration.ini and change “USBCOMP=8” and run the driver setup again
                Rma
                    September 18, 2023,  1:38pm
                  7
              Okay thanks i will try that, and then i will give you an update.
                Rma
                    September 19, 2023,  7:27am
                  8
now this one show up in the Device Manager, but it seems not correct.
I installed the Driver 5087 with the Configuration and tried both ways USB COMP 8 and 99
                jyijyi
                    September 19, 2023,  7:41am
                  9
              I saw there is modem port,  but not sure why the driver is not installed properly.
Have you tried another windows pc?
                Rma
                    September 19, 2023,  8:08am
                  10
              yes thats strange, tried every USB Port, now i will try another PC. I will give you an update then
                Rma
                    September 19, 2023,  8:22am
                  11
              sooo… still the same Problem, is it possible that my USB M2 adpater is not working correct?
                jyijyi
                    September 19, 2023,  8:24am
                  12
              did you see problem in linux PC?
                Rma
                    September 19, 2023,  8:26am
                  13
              Can you show me wich adapter should work?
                jyijyi
                    September 19, 2023,  8:27am
                  14
              i don’t use M2 adaptor, I use the EM7455 dev kit.
can you double click the modem port and see why there is installation problem in device manager?
                Rma
                    September 19, 2023,  8:34am
                  15
              Which Dev Kit do you use?
In the Device Manager it says, This Device cannot start Code 10
                jyijyi
                    September 19, 2023,  8:36am
                  16
              I used this development kit:
can you update the driver?
You need to use 7zip to unzip the  Driver 5087
                Rma
                    September 19, 2023,  9:05am
                  17
              Thanks for the Information.
After Clicking Update Driver, it shows or says the best driver for your device are already installed.
                jyijyi
                    September 19, 2023,  9:06am
                  18
              then why it still show like this?
Did i something wrong?
 [LTE Modul Driver]
                Rma
                    September 19, 2023, 12:09pm
                  19
              I have no idea, this is my setup right now. I will buy some other Adapte or the Dev Kit. Maybe then it will work, or do you have something else in mind what i can try.
                jyijyi
                    September 19, 2023,  1:10pm
                  20
              I suggest you to ask a linux engineer to try in linux pc
