EM7430 shows 'No Service' and cannot install updates. Requesting assistance.
插拔模块,dev目录无变化,不能使用at指令
what did you see in dmesg?
how about adding this?
echo 413C 81CC > /sys/bus/usb-serial/drivers/qcserial/new_id
Thank you very much. I have changed DW5816e to the universal EM7430. As for the driver, I forced it to be installed under Windows and then changed it using the at command. It was perfect. Thank you!
I still have two EM7430 vid 1199 pid 9076, which should be on Panasonic computers, and I am working hard to resolve them.
Hello, I have three modules. Two of them have been successfully modified, but one module only outputs “error” when using the command AT!ENTERCND=“A710”. Has the password of this module been changed?
按照这个网站 Sierra Wireless EM7455: how to make it work with an older Lenovo laptop | zukota.com 使用华为的驱动,可以发送AT命令
yes, i think so, you need to enter the correct password
I don’t know the password. Is it a situation with no solution?
you need to ask the owner of this module
Is there a method to force firmware updates? Or force a factory reset?
what did you see in device manager now?
BTW, have you tried in linux?
I haven’t tried it under Linux
Can QFIL be used to force updates on Windows?
i don’t know, you can try it or try in linux
the same chipset is running inside i think.
yes, DW5816e should be using same chipset as EM7430
