Are you sure that its actually working ? I’m pretty sure it doesn’t work in this state, as it will remain in low-power mode, and not actually power up the modem; this may be the reason you have no GPS
What does the output of at!pcinfo? say ? It should look like this:
at!pcinfo?
State: Online
LPM voters - Temp:0, Volt:0, User:0, W_DISABLE:0, IMSWITCH:0, BIOS:0, LWM2M:0, 0
LPM persistence - None
If it doesn’t, the modem is not actually operational (did you make an LTE connection under windows ?)
But I guess its “good” that yours too, doesn’t show any firmware in any of the slots, although, similar to mine.
A “genuine” 7455 looks like this (this is the mPCIe version of the 7455):
AT!PRIID?
PRI Part Number: 9904514
Revision: 001.006
Customer: Generic-M2M
Carrier PRI: 9999999_9904609_SWI9X30C_02.24.03.00_00_GENERIC_002.021_000
at!image?
FW 1 GOOD 1 0 0 ?? 02.24.03.00?
FW 2 EMPTY 0 0 0
FW 3 EMPTY 0 0 0
FW 4 EMPTY 0 0 0
Max FW images: 4
Active FW image is at slot 1
PRI FF GOOD 0 0 0 002.021_000 02.24.03.00_GENERIC
Max PRI images: 50
My guess is that these are all very early engineering samples, hence they are missing all of the regulartory approval IDs, etc, and come with a 00.xx firmware.
Once you get it out of LPM, the GPS should work just fine. My works without anything connected to the GPS antenna connector (I also have mine in a USB to M.2 adapter, all metal)
