i have module em7430, OEM dell dw5816e, connect to PC with USB 3.0 converter
i have flash the Generic firmware, and it work fine. After that, i am working to make it work with my current country cellular, so i try to change VID:PID, IMEI and USBCOMP with AT command as bellow:
AT!USBVID=1199
AT!USBPID=68b1
AT!USBCOMP=1,3,10D
AT!OPENLOCK… → change imei with openlock code and NVIMEI command
AT!RESET
So, the problem come. after modem reset, it come with mbim but no other com port detected
i was try alot of method but nothing works. flash firmware, swi_comport script, complie and install MBPL USB serial, etc…
only i have now is MBIM interface (dmesg result)
[17081.238278] hub 3-0:1.0: USB hub found
[17081.238343] hub 3-0:1.0: 15 ports detected
[17081.572134] usb 3-1: new SuperSpeed USB device number 2 using xhci_hcd
[17081.594832] usb 3-1: New USB device found, idVendor=1199, idProduct=68b1, bcdDevice= 0.06
[17081.594838] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[17081.594839] usb 3-1: Product: EM7430
[17081.594841] usb 3-1: Manufacturer: Sierra Wireless, Incorporated
[17081.594842] usb 3-1: SerialNumber: LR84727330031013
[17081.618356] cdc_mbim 3-1:1.0: cdc-wdm0: USB WDM device
[17081.619674] cdc_mbim 3-1:1.0 wwan0: register ‘cdc_mbim’ at usb-0000:02:1b.0-1, CDC MBIM, 72:6f:9d:d8:b1:a4
Whats solution i be able to try now ? anyway to reset or fix this ?
I have try that way, by navigate to C:\Program Files (x86)\Sierra Wireless Inc\Driver Package and using DriverInst to do some driver change with xml file… not fix this. i was try with flag USBCOMP=8 as 73xx but its not work also
after alot of trying, it showing serial port on dmesg, but it was not registered as ttyUSB device
my works are adding device vid pid on qcserial.c as bellow → re-complie and install it with make → reboot → using modprobe to registering new device
i am adding on both static const struct , also try again with another module type 74xx as {DEVICE_SWI(0x1199, 0x9078)}, /* Sierra Wireless EM74xx */
qcserial.c (30.6 KB)
this is the modified file that i complie and install with usb-src, you can searching the line with “edited” explain mark
i was try command modprobe and echo for each driver type i have installed, none of them give me the ttyUSB device registred
dmesg detect 3 serial port, but i still cannot register that port to ttyUSB device
484.081425] usb 2-5.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 484.081432] usb 2-5.1: Product: EM7430
[ 484.081437] usb 2-5.1: Manufacturer: Sierra Wireless, Incorporated
[ 484.081443] usb 2-5.1: SerialNumber: LR84727330031013
[ 484.084272] usb 2-5.1: Enable of device-initiated U1 failed.
[ 484.085209] usb 2-5.1: Enable of device-initiated U2 failed.
[ 484.085703] usbserial_generic 2-5.1:1.0: The “generic” usb-serial driver is only for testing and one-off prototypes.
[ 484.085716] usbserial_generic 2-5.1:1.0: Tell linux-usb@vger.kernel.org to add your device to a proper driver.
[ 484.085729] usbserial_generic 2-5.1:1.0: device has no bulk endpoints
[ 484.111536] cdc_mbim 2-5.1:1.0: cdc-wdm2: USB WDM device
[ 484.112562] cdc_mbim 2-5.1:1.0 wwan0: register ‘cdc_mbim’ at usb-0000:00:14.0-5.1, CDC MBIM, 76:1d:b8:61:fd:82
[ 484.113265] usb 2-5.1: Enable of device-initiated U1 failed.
[ 484.114105] usb 2-5.1: Enable of device-initiated U2 failed.
root@NUC9i5QNX:~#
lsusb -t are just showing 2 mbim interface port
: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/10p, 10000M
|__ Port 4: Dev 2, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
|__ Port 5: Dev 3, If 0, Class=Hub, Driver=hub/4p, 10000M
|__ Port 1: Dev 6, If 0, Class=Communications, Driver=cdc_mbim, 5000M
|__ Port 1: Dev 6, If 1, Class=CDC Data, Driver=cdc_mbim, 5000M
i was try the modprobe and echo, but it do not work anyway
Is this linux pc ok to connnect good module before to show ttyusbx ?
I saw these new lines
no, ttyUSB device wasnt found on /dev
ls /dev/ | grep USB result nothing
i was intall ubuntu and troubleshoot it with physical pc on today, but it seem doesnt work ethier
