EM7565 stuck in QMI mode but only with one DIAG port
Hi! I realy need your help.
After my not quite competent conversion from full MBIM to QMI (but wrong mode),
AT!USBCOMP?
AT!USBCOMP=1,3,0101
AT!RESET
I have no way to change the modem composition and activate the AT port.
I have tried windows driver with changed parameters,
[Default Values]
SILENT=0
SS=1
MBBDRIVER=1
LOCATIONDRIVER=1
WIN8LOCATION=1
LOG=1
BUSDRIVER=1
WIN8BUSDRIVER=1
USBCOMP=8
CHECKFORDEVICE=0
GPS=1
GPSAUTO=1
GPSRADIO=1
DisableUsbCompAutoUpdate=1
With no luck.
This also
root@ImmortalWrt:~# qmicli -d /dev/cdc-wdm0 --dms-get-operating-mode
[/dev/cdc-wdm0] Operating mode retrieved:
        Mode: 'online'
        HW restricted: 'no'
root@ImmortalWrt:~# qmicli -d /dev/cdc-wdm0 --dms-swi-set-usb-composition=8
error: couldn't set USB composite modes: QMI protocol error (94): 'NotSupported'
Also I have reflashed firmware. Also no luck/changes.
Here additional hw info. I’d appreciate the help.
Aleksei
root@ImmortalWrt:~# lsusb -t -v
/: Bus 001.Port 001: Dev 001, Class=root_hub, Driver=xhci-mtk/2p, 480M
 ID 1d6b:0002
/: Bus 002. Port 001: Dev 001, Class=root_hub, Driver=xhci-mtk/1p, 20000M/x2
 ID 1d6b:0003
 |__ Port 001: Dev 002, If 0, Class=[unknown], Driver=qcserial, 5000M/x2
 ID 1199:9091
 |__ Port 001: Dev 002, If 8, Class=[unknown], Driver=qmi_wwan, 5000M/x2
 ID 1199:9091
T:  Bus=02 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#=  2 Spd=5000 MxCh= 0
D:  Ver= 3.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 9 #Cfgs=  1
P:  Vendor=1199 ProdID=9091 Rev= 0.06
S:  Manufacturer=Sierra Wireless, Incorporated
S:  Product=Sierra Wireless EM7565 Qualcomm® Snapdragon™ X16 LTE-A
S:  SerialNumber=UF02910148031047
C:* #Ifs= 2 Cfg#= 1 Atr=a0 MxPwr=896mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=qcserial
E:  Ad=81(I) Atr=02(Bulk) MxPS=1024 Ivl=0ms
E:  Ad=01(O) Atr=02(Bulk) MxPS=1024 Ivl=0ms
I:* If#= 8 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=qmi_wwan
E:  Ad=82(I) Atr=03(Int.) MxPS=   8 Ivl=32ms
E:  Ad=8e(I) Atr=02(Bulk) MxPS=1024 Ivl=0ms
E:  Ad=0f(O) Atr=02(Bulk) MxPS=1024 Ivl=0ms
Can you do AT command with the only port enumerated?
Can you see /dev/ttyUSBx port in linux?
not sure if it works if you change the USBCOMP to 9 in configuration.ini
You can double check:
Continuing the discussion from EM7565 stuck in QMI mode but only with one DIAG port:
Hi!
I already tried to modify configuration.ini and ran with following way:
GenericDriverSetup_5087.exe USBCOMP=8 DisableUsbCompAutoUpdate=1
GenericDriverSetup_5087.exe USBCOMP=6 DisableUsbCompAutoUpdate=1
In Linux and ImmortalWRT I can see only ttyUSB0 unfortunately.
how about changing the USBCOMP to 9 in configuration.ini?
I have tried now. No luck. Just DM port.
ttyUSB0 not reacting for AT-commands.
probably you need to contact Sierra FAE to get a tool to configure it
How to reach this guys (Sierra FAE)? Maybe there are another approach to fix it?
how about changing the USBCOMP to 9 in configuration.ini and reinstall the windows driver?
I have tried with no luck
You need to contact distributor to get a tool called setusbcomp.exe for em7565 module
Is the any advices how to do it, due to I have bought it in on aliexpress?
can you return the goods there as it is not fully functioning?
I don’t think so, due to it’s result of my activities. Better to fix it, if it’s possible.
How about using qmicli to do factory reset?
How to do it?
does this work?
I’m trying to restore a proper USB composition that includes a working AT command port on a Sierra Wireless EM7565, so I can switch to MBIM (e.g. AT!USBCOMP=1,3,100D) and have Linux expose cdc_mbim instead of QMI-only behavior.​
On my OpenWrt-based router the modem enumerates mostly as QMI (qmi_wwan), and I cannot reliably access an AT port / get AT responses to change composition.
Attempts (what I tried)
1) Linux: AT!USBCOMP over ttyUSB
  • Tried sending via picocom and also via printf ... > /dev/ttyUSB0:
    AT!ENTERCND="A710", AT!USBCOMP=1,3,100D, AT!RESET.
  • The modem re-enumerates sometimes, but composition stays QMI (still qmi_wwan, no cdc_mbim).
  • I couldn’t reliably see OK responses from that port; it may not be the real AT port (possibly DIAG).
  • Reference: typical procedure for MBIM uses AT!USBCOMP=1,3,100D.​
2) Linux: QMI SWI USB composition API
  • qmicli --version: 1.34.0.
  • qmicli -d /dev/cdc-wdm0 --dms-swi-get-usb-composition → QMI protocol error (94): NotSupported.
  • Same for --dms-swi-set-usb-composition.
    (So composition switching via SWI QMI extensions is not available on this FW/PRI.)​
3) Linux: DIAG tools (bkerler/edl → qc_diag)
  • Used bkerler/edl qc_diag on interface 0 (VID/PID 1199:9091).​
  • qc_diag has no AT passthrough functionality (help lists only info/cmd/sp/spc/nv*/efs*).
  • NV reads / nvbackup: most items return Bad Parameter/restricted; I couldn’t locate a writable USB composition NV item.
  • EFS browsing: root / and /nv list OK, but many subpaths return Directory not open; some paths (e.g. /nvup, /nvm) crash with struct.error: unpack requires a buffer of 4 bytes.
  • Tried guessed raw DIAG vendor commands → Invalid Command Response.
  • qc_diag crash is accepted and reboots the modem, but composition remains QMI.
4) Firmware update attempts (Linux/OpenWrt + Ubuntu Live)
  • I already tried several recent firmware versions (last ~3–4 versions I had), but the issue persists across them.
  • Tried flashing from Live Ubuntu 24.04 using fwdwl-lite (firmware download tool).
  • Also tried flashing from OpenWrt via QMI, and also when the adapter enters a QDL/QDL-like download mode during “direct flashing” attempts (it drops into download mode in the process).
5) Windows attempt (during driver install)
  • Under Windows (during Sierra driver installation / device setup), I tried changing/restoring the USB composition / AT port, but still didn’t end up with a stable AT+MBIM composition that works back on Linux/OpenWrt.
Logs (key outputs)
  • QMI works: /dev/cdc-wdm0 exists; qmicli --dms-get-model returns EM7565; operating mode shows online.
  • qmicli --dms-get-firmware-preference shows Generic firmware/PRI (currently 01.14.22.00_GENERIC / 002.059_002).
  • lsusb -t typically shows qmi_wwan on interface 8; interface 0 is either qcserial or unbound.
  • qmicli --dms-swi-get-usb-composition returns NotSupported.
Firmware packages I have locally
  • I have multiple firmware packages. I already tested the most recent ~3–4 that I had.
  • I also have a very old package available but haven’t tried downgrading to it yet:
    SWI9X50C_01.05.01.00.cwe + SWI9X50C_01.05.01.00_GENERIC_001.028_000.nvu.
Questions to the forum
  1. Is there a known way to restore an AT port / full composition on EM7565 without relying on Windows, when SWI QMI composition commands are NotSupported and DIAG NV access seems blocked?​
  2. Would downgrading to the much older firmware (01.05.01.00 / 001.028.000) likely restore a default composition that exposes AT, or enable SWI QMI USB composition switching?
  3. Is there a recommended “recovery” USB composition value (or recovery procedure) for EM7565 that reliably brings back AT + DM + MBIM interfaces?​
If needed, I can paste full command outputs (lsusb -t, dmesg | grep -E 'qcserial|qmi_wwan|ttyUSB', qmicli --dms-get-firmware-preference, and the exact NotSupported errors).
qmicli -d /dev/cdc-wdm0 --dms-restore-factory-defaults=“000000”
error: couldn’t create client for the ‘dms’ service: CID allocation failed in the CTL client: Transaction timed out
error: couldn’t create input data bundle: ‘Input variable ‘value_service_programming_code’ must be 6 characters long’
What do you see in windows pc?
