sudo qmicli --device-open-mbim -p -d /dev/cdc-wdm0 --dms-swi-set-usb-composition=6
[/dev/cdc-wdm0] Successfully set USB composition
You may want to power-cycle the modem now, or just set it offline and reset it:
$> sudo qmicli ... --dms-set-operating-mode=offline
$> sudo qmicli ... --dms-set-operating-mode=reset
sudo qmicli --device-open-mbim -p -d /dev/cdc-wdm0 --dms-set-operating-mode=reset
[/dev/cdc-wdm0] Operating mode set successfully
couldn’t QMI devices /dev/cdc-wdm0
After executing the above command, the QMI device was no longer recognized and I was unable to do anything.
Is there any way to cure it?
lsusb && lsusb -t
Bus 002 Device 002: ID 13fd:3920 Initio Corporation INIC-3619PN SATA Bridge
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 1199:9077 Sierra Wireless, Inc. EM7430
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
|__ Port 2: Dev 2, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 3: Dev 3, If 0, Class=Vendor Specific Class, Driver=, 480M
|__ Port 3: Dev 3, If 2, Class=Vendor Specific Class, Driver=, 480M
|__ Port 3: Dev 3, If 3, Class=Vendor Specific Class, Driver=, 480M
|__ Port 3: Dev 3, If 8, Class=Vendor Specific Class, Driver=, 480M
T: Bus=01 Lev=02 Prnt=02 Port=02 Cnt=01 Dev#= 3 Spd=480 MxCh= 0
D: Ver= 2.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1199 ProdID=9077 Rev=00.06
S: Manufacturer=Sierra Wireless, Incorporated
S: Product=EM7430
S: SerialNumber=LR
C: #Ifs= 4 Cfg#= 1 Atr=a0 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I: If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=83(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
I: If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=85(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
I: If#= 8 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=87(I) Atr=03(Int.) MxPS= 8 Ivl=32ms
[ 2.339337] usb 1-1.3: config 1 has an invalid interface number: 8 but max is 3
[ 2.339370] usb 1-1.3: config 1 has no interface number 1
[ 2.340201] usb 1-1.3: New USB device found, idVendor=1199, idProduct=9077, bcdDevice= 0.06
[ 2.340229] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.340243] usb 1-1.3: Product: EM7430
[ 2.340254] usb 1-1.3: Manufacturer: Sierra Wireless, Incorporated
[ 2.340262] usb 1-1.3: SerialNumber: LR*****
