We are able to achieve 70 Mbps downlink with the same Network & other UE(Bittium Phone).
From the specs, its mentioned 150 Mbps(DL) & 50 Mbps(UL) for 20 MHz Bandwidth. Please correct me If I am wrong.
changing any settings on the modem will improve the downlink ?
Please let us know your inputs.
So do you have both antennas connected or a single one? Generically speaking the unit will go as fast as the network will allow it to, there are no settings on the unit that will change this, you are also going to need to be a little more specific/detailed about your test method.
We had 2 antennas connected.
We are able to get the DL around 65 Mbps for the 20MHz Bandwidth.
But the same test setup with the other UE gives around 120+ Mbps.
we are using the below iperf commands in both the cases
iperf –s –u –i 2 –p 4321
iperf –c 172.22.1.201 –u –b 60m –t 1000 –p 5002 –l 1470
Any suggestions why we are not able to get the same numbers ?
Let me know if you are looking for more information . so that I can share with you.
The only way to sensibly test throughput is to use it against atest set like a CMW so that you have end to end control. I do not know what is limiting the unit here but there is clearly something reducing the performance of the unit.
