So I setup a MC7455 in a WE826 router. It’s up and running but I’m having issues with speeds. On my Note8 I get 40-60 Mbps down easily. On my router setup, I’m connected and only getting between 5-15 Mbps down (upload is always higher, 10-20). I verified I’m connected to same tower and on the same band (B4).
Any ideas/advice is much appreciated.
Thanks!
lotam
August 28, 2018, 2:42am
2
Hi mathena2,
Throughput is affected by many factors, network/signal/band, USB interface/driver, host, etc.
Can you share more info:
Which driver and how data connection is established on WE826?
Any chance WE826 is using PPPD?
Does same issue happen when you test MC7455 connect to PC (over USB)?
Please check and share “AT!GSTATUS?” return?
And you may get some info from similar post below using same WE826:
Thank you very much for your suggestion DL5162. I switched to LEDE and everything is working nicely.
Tony.
Thx
lotam:
Hi mathena2,
MC7455 connects with Barrier Breaker ZBT WE826 router - #3 by knguyen1
Thx
Not sure on driver… does this help? - ROOter ZBT-WE826 GoldenOrb_ Build 2017-12-15, LEDE 17.01.4 r3560-79f57e422d
What is PPPD?
Do not have a a USB enclosure for it. It’s hooked up inside router
Current Time: 6774 Temperature: 47
Reset Counter: 1 Mode: ONLINE
LTE band: B4 LTE bw: 20 MHz
LTE Rx chan: 2150 LTE Tx chan: 20150
LTE CA state: NOT ASSIGNED
RRC state: RRC Connected
IMS reg state: No Srv
PCC RxM RSSI: -69 RSRP (dBm): -97
PCC RxD RSSI: -70 RSRP (dBm): -102
Tx Power: 0 TAC: 7400 (29696)
RSRQ (dB): -15.1 Cell ID: 01C53D16 (29703446)
SINR (dB): 4.6
lotam
August 28, 2018, 3:35am
4
Sorry, I don’t have info about WE826.
But seems like signal is not good, maybe you can check (or try different) antenna?
Thx
