AAF Connection to Server Failed / RV55 AAF Issues
  • Model: RV55
  • Firmware Revision: 4.18.1
I’m experiencing some issues when trying to upload an application to an RV55. More accurately, I keep getting the error “Error : AAF connection to server failed (22)” and occasionally “Error : AAF connection to server failed (28)” when trying to establish a connection in order to successfully upload an application. At this moment, I’m stuck on “In Progress” indefinitely.
Things I’ve double checked and confirmed.
  1. Application has been added to Firmware & Applications via Systems > Device > Edit
  2. AirVantage and Device have matching M3DA Protocol Password
  3. I’ve listed 44900 in Allowed Inbound and Outbound Ports
  4. I and my account is based in North America so I am using the MSCI Server URL “https://na.m2mop.net/device/msci/com”
  5. I’ve Enabled ALEOS Application Framework on the device via Applications > ALEOS Application Framework > Enabled
  6. The device successfully communicates with AirVantage, I’m able to push Templates, Synchronize, etc. The communication Status is Green
  7. The device is using a Verizon Cellular Line set with a Static Public IP Address
  8. I’ve uploaded the application locally to the device with no issue.
Below is a snippet of the logs from the device.
Oct 31 15:45:28 [notice ] ALEOS_APPS Stopping AAF Agent…
Oct 31 15:45:28 [notice ] AAF APPMON-WARNING: SIGCHLD_handler: detected privileged_app death, closing command client socket
Oct 31 15:45:36 [err ] ALEOS_SYSTEM_CSM Destination message queue /RAreg2 has 10 msgs out of 10 max
Oct 31 15:45:36 [err ] ALEOS_SYSTEM_CSM Notifying clients: Sending notification (MSCIID 2798) to client /RAreg2 failed
Oct 31 15:45:37 [err ] ALEOS_SYSTEM_CSM Destination message queue /RAreg2 has 10 msgs out of 10 max
Oct 31 15:45:37 [err ] ALEOS_SYSTEM_CSM Notifying clients: Sending notification (MSCIID 10738) to client /RAreg2 failed
Oct 31 15:45:38 [err ] ALEOS_CELL_RadioTask sendToCsm Did not receive confirmation of set from CSM.
Oct 31 15:45:38 [err ] ALEOS_CELL_RadioTask Failed to send update to CSM
Oct 31 15:45:38 [err ] ALEOS_SYSTEM_CSM Destination message queue /RAreg2 has 10 msgs out of 10 max
Oct 31 15:45:38 [err ] ALEOS_SYSTEM_CSM Notifying clients: Sending notification (MSCIID 10257) to client /RAreg2 failed
Oct 31 15:45:39 [err ] ALEOS_SYSTEM_CSM Destination message queue /RAreg2 has 10 msgs out of 10 max
Oct 31 15:45:39 [err ] ALEOS_SYSTEM_CSM Notifying clients: Sending notification (MSCIID 10211) to client /RAreg2 failed
Oct 31 15:45:40 [err ] ALEOS_SYSTEM_CSM Destination message queue /RAreg2 has 10 msgs out of 10 max
Oct 31 15:45:40 [err ] ALEOS_SYSTEM_CSM Notifying clients: Sending notification (MSCIID 2798) to client /RAreg2 failed
Oct 31 15:45:41 [err ] ALEOS_CELL_RadioTask sendToCsm Did not receive confirmation of set from CSM.
Oct 31 15:45:41 [err ] ALEOS_CELL_RadioTask Failed to send update to CSM
Oct 31 15:45:41 [err ] ALEOS_SYSTEM_CSM Destination message queue /RAreg2 has 10 msgs out of 10 max
Oct 31 15:45:41 [err ] ALEOS_SYSTEM_CSM Notifying clients: Sending notification (MSCIID 10738) to client /RAreg2 failed
Oct 31 15:45:42 [err ] ALEOS_SYSTEM_CSM Destination message queue /RAreg2 has 10 msgs out of 10 max
Oct 31 15:45:42 [err ] ALEOS_SYSTEM_CSM Notifying clients: Sending notification (MSCIID 10256) to client /RAreg2 failed
Oct 31 15:45:43 [err ] ALEOS_SYSTEM_CSM Destination message queue /RAreg2 has 10 msgs out of 10 max
Oct 31 15:45:43 [err ] ALEOS_SYSTEM_CSM Notifying clients: Sending notification (MSCIID 10211) to client /RAreg2 failed
Oct 31 15:46:13 [notice ] ALEOS_SERVICES_SNTP SNTP: Time was previously not valid
Oct 31 15:46:13 [err ] ALEOS_SYSTEM_CSM Destination message queue /RAreg2 has 10 msgs out of 10 max
Oct 31 15:46:13 [err ] ALEOS_SYSTEM_CSM Notifying clients: Sending notification (MSCIID 10211) to client /RAreg2 failed
Oct 31 15:46:14 [err ] ALEOS_SYSTEM_CSM Destination message queue /RAreg2 has 10 msgs out of 10 max
Oct 31 15:46:14 [err ] ALEOS_SYSTEM_CSM Notifying clients: Sending notification (MSCIID 10211) to client /RAreg2 failed
Oct 31 15:46:15 [err ] ALEOS_SYSTEM_CSM Destination message queue /RAreg2 has 10 msgs out of 10 max
Oct 31 15:46:15 [err ] ALEOS_SYSTEM_CSM Notifying clients: Sending notification (MSCIID 57000) to client /RAreg2 failed
Oct 31 15:46:16 [err ] ALEOS_SYSTEM_CSM Destination message queue /RAreg2 has 10 msgs out of 10 max
Oct 31 15:46:16 [err ] ALEOS_SYSTEM_CSM Notifying clients: Sending notification (MSCIID 2798) to client /RAreg2 failed
Oct 31 15:46:17 [err ] ALEOS_SYSTEM_CSM Destination message queue /RAreg2 has 10 msgs out of 10 max
Oct 31 15:46:17 [err ] ALEOS_SYSTEM_CSM Notifying clients: Sending notification (MSCIID 55055) to client /RAreg2 failed
Oct 31 15:46:18 [err ] ALEOS_SYSTEM_CSM Destination message queue /RAreg2 has 10 msgs out of 10 max
Oct 31 15:46:18 [err ] ALEOS_SYSTEM_CSM Notifying clients: Sending notification (MSCIID 10740) to client /RAreg2 failed
Oct 31 15:46:18 [notice ] ALEOS_SYSTEM_Cmdexe M3DA provisioning password modified, reset M3DA credentials
Oct 31 15:46:19 [err ] ALEOS_SYSTEM_CSM Destination message queue /RAreg2 has 10 msgs out of 10 max
Oct 31 15:46:19 [err ] ALEOS_SYSTEM_CSM Notifying clients: Sending notification (MSCIID 10255) to client /RAreg2 failed
Oct 31 15:46:20 [err ] ALEOS_SYSTEM_CSM Destination message queue /RAreg2 has 10 msgs out of 10 max
Oct 31 15:46:20 [err ] ALEOS_SYSTEM_CSM Notifying clients: Sending notification (MSCIID 10211) to client /RAreg2 failed
Oct 31 15:46:20 [notice ] ALEOS_SERVICES_SNTP Current time: Fri, 31 Oct 2025 15:43:32 UTC SNTP time used to set both system time and HW clock system time to: Fri, 31 Oct 2025 15:46:20 UTC
Oct 31 15:46:20 [notice ] ALEOS_SERVICES_SNTP Seconds since boot: 149
Oct 31 15:46:21 [err ] ALEOS_SYSTEM_CSM Destination message queue /RAreg2 has 10 msgs out of 10 max
Oct 31 15:46:21 [err ] ALEOS_SYSTEM_CSM Notifying clients: Sending notification (MSCIID 55042) to client /RAreg2 failed
Oct 31 15:46:22 [err ] ALEOS_SYSTEM_CSM Destination message queue /RAreg2 has 10 msgs out of 10 max
Oct 31 15:46:22 [err ] ALEOS_SYSTEM_CSM Notifying clients: Sending notification (MSCIID 10211) to client /RAreg2 failed
Oct 31 15:46:23 [err ] ALEOS_SYSTEM_CSM Destination message queue /RAreg2 has 10 msgs out of 10 max
Oct 31 15:46:23 [err ] ALEOS_SYSTEM_CSM Notifying clients: Sending notification (MSCIID 55055) to client /RAreg2 failed
Oct 31 15:46:24 [err ] ALEOS_SYSTEM_CSM Destination message queue /RAreg2 has 10 msgs out of 10 max
Oct 31 15:46:24 [err ] ALEOS_SYSTEM_CSM Notifying clients: Sending notification (MSCIID 2798) to client /RAreg2 failed
Oct 31 15:46:25 [err ] ALEOS_SYSTEM_CSM Destination message queue /RAreg2 has 10 msgs out of 10 max
Oct 31 15:46:25 [err ] ALEOS_SYSTEM_CSM Notifying clients: Sending notification (MSCIID 10211) to client /RAreg2 failed
Oct 31 15:46:26 [err ] ALEOS_SYSTEM_CSM Destination message queue /RAreg2 has 10 msgs out of 10 max
Oct 31 15:46:26 [err ] ALEOS_SYSTEM_CSM Notifying clients: Sending notification (MSCIID 65000) to client /RAreg2 failed
Oct 31 15:46:27 [err ] ALEOS_SYSTEM_CSM Destination message queue /RAreg2 has 10 msgs out of 10 max
Oct 31 15:46:27 [err ] ALEOS_SYSTEM_CSM Notifying clients: Sending notification (MSCIID 10740) to client /RAreg2 failed
Oct 31 15:46:28 [err ] ALEOS_SYSTEM_CSM Destination message queue /RAreg2 has 10 msgs out of 10 max
Oct 31 15:46:28 [err ] ALEOS_SYSTEM_CSM Notifying clients: Sending notification (MSCIID 10211) to client /RAreg2 failed
Oct 31 15:46:29 [notice ] ALEOS_APPS Starting AAF Agent…
Oct 31 15:46:29 [warning] ALEOS_APPS_AAF-AGENT Loading PersistStore from file /mnt/user/readyagent/persist/PersistStore.l2b
Oct 31 15:46:29 [warning] ALEOS_APPS_AAF-AGENT Loading ConfigStore from file /mnt/user/readyagent/persist/ConfigStore.l2b
Oct 31 15:46:29 [err ] ALEOS_SYSTEM_CSM Destination message queue /RAreg2 has 10 msgs out of 10 max
Oct 31 15:46:29 [err ] ALEOS_SYSTEM_CSM Notifying clients: Sending notification (MSCIID 10211) to client /RAreg2 failed
Oct 31 15:46:31 [warning] ALEOS_APPS_AAF-AGENT Setting authentication and encryption key
Oct 31 15:46:31 [warning] ALEOS_APPS_AAF-AGENT K =82 7c cb 0e ea 8a 70 6c 4c 34 a1 68 91 f8 4e 7b
Oct 31 15:46:31 [warning] ALEOS_APPS_AAF-AGENT KS=8e 99 1e 71 9a a3 95 52 e8 43 83 0c 95 bc df 09
Oct 31 15:46:31 [warning] ALEOS_APPS_AAF-AGENT KD=35 24 46 65 8f 7c e5 d0 ee 2e 17 6e 75 a9 98 58
Oct 31 15:46:31 [warning] ALEOS_APPS_AAF-AGENT Keys written in store
Oct 31 15:46:31 [notice ] AAF APPMON-WARNING: SIGCHLD_handler: detected privileged_app death, closing command client socket
Oct 31 15:46:32 [crit ] ALEOS_SYSTEM_CSM ACMIMsgQ: /RAreg2 mq_open failed while send ‘No such file or directory’
Oct 31 15:46:32 [err ] ALEOS_SYSTEM_CSM Notifying clients: Sending notification (MSCIID 2798) to client /RAreg2 failed, removing client from notification list
Oct 31 15:46:36 [warning] ALEOS_APPS_AAF-AGENT Loading PersistStore from file /mnt/user/readyagent/persist/PersistStore.l2b
Oct 31 15:46:36 [warning] ALEOS_APPS_AAF-AGENT Loading ConfigStore from file /mnt/user/readyagent/persist/ConfigStore.l2b
Oct 31 15:46:38 [warning] ALEOS_APPS_AAF-AGENT Loading ack_policy_daily from file /mnt/user/readyagent/persist/ack_policy_daily.l2b
Oct 31 15:46:38 [warning] ALEOS_APPS_AAF-AGENT Loading ack_policy_default from file /mnt/user/readyagent/persist/ack_policy_default.l2b
Oct 31 15:46:38 [warning] ALEOS_APPS_AAF-AGENT Loading ack_policy_hourly from file /mnt/user/readyagent/persist/ack_policy_hourly.l2b
Oct 31 15:46:38 [warning] ALEOS_APPS_AAF-AGENT Loading ack_policy_never from file /mnt/user/readyagent/persist/ack_policy_never.l2b
Oct 31 15:46:38 [warning] ALEOS_APPS_AAF-AGENT Loading ack_policy_now from file /mnt/user/readyagent/persist/ack_policy_now.l2b
Oct 31 15:46:38 [warning] ALEOS_APPS_AAF-AGENT Loading ack_policy_onboot from file /mnt/user/readyagent/persist/ack_policy_onboot.l2b
Oct 31 15:46:38 [warning] ALEOS_APPS_AAF-AGENT Loading SDB_File_Tables from file /mnt/user/readyagent/persist/SDB_File_Tables.l2b
Oct 31 15:46:38 [warning] ALEOS_APPS_AAF-AGENT Server URL = “tcp://lw.na.airvantage.net:44900”
Oct 31 15:47:53 [err ] ALEOS_APPS_AAF-AGENT Failed with status NOREPORT: “/usr/readyagent/lua/m3da/session/security.lua:55: closed”
Oct 31 15:47:53 [err ] ALEOS_APPS_AAF-AGENT Error while sending data to server: Failed with code 500
Oct 31 15:47:53 [err ] ALEOS_APPS_AAF-AGENT Unexpected error while executing rest request server: Failed
Thank you,
Hi @nicholas.rieches,
Could you please share the full log file and template file with me.
***Here are the instructions for obtaining the log file and template file:
  1. The template file can be found in ACEmanager → Template. Provide any desired name for the Template Name, and then press Download to retrieve the template file.
  2. Obtain the log file:
    a. Go to AceManager > Admin > Log > Configure Logging.
    • Set all log levels to DEFAULT (NOTICE).
    • Set Linux Syslog to DISPLAY.
    • Then select Apply.
    b. Reboot the gateway.
    • Reproduce the issue
    c. Go to Admin → View log → Download Logs.
