Is it possible to put an XR80 into a passthru or modem mode? Basically just use the XR80 as a modem with another router behind it. Trying to work on some different type of configuration, but would like to use a router behind the XR80 instead of using the XR80 for my routing.
Hi @jpalsi,
IPv4 Passthrough feature allows a LAN client to use the device Cellular WAN IP. This is useful if the LAN client is acting a a server for the internet (e.g. a web server).
The following are the steps to configure IPv4 passthrough on XR80.
Please log in to the router at 192.168.1.1
- Get on air with ipv4 (You can check by going to Status/ Monitoring > WAN)
- Go to Networking → General → WAN services
- Click 3 dots on IPv4
- Go down to IPv4 Passthrough, and select an Interface (only Ethernet allowed)
- Wait for LAN client device to obtain the WAN IP.
Would this allow me to use another router, say a Ubiquiti EdgeRouter, behind the XR80? I’m hoping to test using the ER as an endpoint for an IPSEC tunnel back to my main network.
I have tried using the XR80 to be the endpoint, but performance it BAD. Just trying to test right now.
Hi @jpalsi,
Could you please follow these steps, if you encounter any issues or have any questions, please let me know.
