We are currently designing a board with an XM1210 GPS module on it in replacement of a previous model which is EOL. This model is also a matter of convenience since we use it on other boards. However, according to the datasheet, the 1PPS signal on this model is only active after being 3D fixed, which will end up raising an alarm in our software if for some reason we loose the 3D_Fix, hence the 1PPS.
Is it possible to order these devices with a custom firmware which would always output a 1PPS signal? It would save us from reprogramming the software which we don’t have the ownership. Thanks a lot in advance.
Have a great day and take care.
