XM1110_1103886 change Baud Rate
We’ve bought GNSS XM1110_1103886 (Firmware AXN 5.1.1_8252). I can’t change Baud Rate from 115 200bps (default) to 9600bps, using command $PMTK251, 9600*17.
Earlier I used FireFly (Firmware AXN 3.8_8552) and changed Baud Rate to 9600bps, using command $PMTK251, 960017 and vice versa, using command $PMTK251, 1152001F.
Can you please help me?
Thanks in advance.
Note: I have a series of these modules purchased and ran into the same problem. Turned out the baudrate was default 38400 (!). So off-spec. I would try this baudrate to see if you can communicate.
