I have been trying to connect my WP7609 module to a Keysight UXM E7515B, which functions as a base station. The WP7609 has WP76xx_Release16.0.1_GENERIC with a few custom apps, and I am using a mangOH Red board. We are using the UXM because we are based in the US, and there are no AU bands around us.
The Keysight UXM has their own SIM card to connect to the UXM, and I have tested the SIM by putting it in a phone. The phone was able to connect to the internet through LTE through connection to the UXM.
I also have set the correct APN that is used with the UXM, and that is the same APN that the phone has used. Keysight has instructed us to use this APN when using their SIM cards: “Keysight”
I have tested the mangOH Red board as well by connecting a WP7601-1 module to Airvantage using the board.
When I would go to connect to the UXM from the module by calling “cm radio off” and “cm radio on”, it would briefly connect to the UXM and then disconnect. So if I called “cm radio” before it connected, it would say:
Power: ON
Current Network Operator: Agilent TS34.108
Current RAT: Module not registered on network, RAT not available
Status: Registration was denied, usually because of invalid access credentials (LE_MRC_REG_DENIED)
Signal: Very strong signal strength (5)
PS: Packet Switched Not registered (LE_MRC_REG_NONE)
Then calling “cm radio” again right after it tried to connect it would give me:
Power: ON
Current RAT: LTE network (LE_MRC_RAT_LTE)
Status: Registered, home network (LE_MRC_REG_HOME)
Signal: Strong signal strength (5)
PS: Packet Switched Registered, home network (LE_MRC_REG_HOME)
Then calling “cm radio” right after the last one it would give me the same thing as before:
Power: ON
Calling “cm data connect&” also did not work either. It would just say ‘Connecting…’ and would never finish.
I think that I am missing something but I don’t know what. Any help would be appreciated, thanks!
