I’m playing around reducing current draw with the WP7609. With no apps running (legato is running), and USB-SS enabled (low power mode), I see ~26s of ~5mA, followed by ~1min of ~30mA. This cycle continues.
Stopping legato altogether and going into low power mode also produces the same results.
I thought that this may be related to EDRX or CPSMS, and have changed the values, but the results are always the same. Then I tried without an active SIM. The value drops from ~5mA to ~2mA, but the ~30mA cycle still continues.
I set AT+CFUN=0 (and 4), to the same ~5mA and ~30mA cycles.
Does anyone know what this behavior is? And if possible, how to change these cycles?
I’ve changed a few things and it behaves more as expected.
A new thing I’m seeing is that I can enter low power (idle) mode now using the sample smsApp and voiceCallApp. On receiving a registered event, like an SMS or call, the current goes back to an active current of around 42mA, before taking about a minute of inactivity to return back to idle mode.
With no USB, it will behave like USB-SS, right? So it will go into the low power mode without USB.
I still see the 1 minute delay before going into lower power mode when I boot the device without the USB plugged in. It behaves like USB-SS. I want to know if it’s possible to shorten this 1 minute delay.
Every time the module shows some activity, like receiving an SMS or call without a USB cable, it has 1 minute high current (20-30mA) before going into low power idle mode (as if going into USB-SS mode)
I don’t have much idea on this, but I remember in the past, I found on WP77 module, if I disable HSIC setting, i can help to go sleep mode.
You can see if there is any improvement.
