I want to use SMS function with SDK, but the return “Invalid/unknown QMI command specified” as figure.
How can I use this function? Or this SDK can’t support WP7607?
SDK version 04.00.19
My module information :
Albert
Hi @alberthuang
This issue has also been reproduced with the latest SDK SLQS04.00.23 on WP7607, Ubuntu 18.04.2. It is returned “Invalid/unknown QMI command specified”.
You can use SMS_Application in SampleApps for SMS function with SDK on WP7607.
Please help to mark “Solution” if your question is answered. So the community could easily find the solution for their problems.
root@ubuntu-OptiPlex-3010:/home/ubuntu/Documents/Driver/SLQS04.00.23.bin/SampleApps/SMS_Application# sudo ./bin/SMSSampleApphostx86_64 ../../build/bin/hostx86_64/slqssdk
Unable to find device..
Please select one of the following options or press <Enter> to exit:
1. Register CallBack
2. Send SMS
3. Read SMS
4. Delete SMS
5. Execute Automated Tests for SMS Encoding Decoding
Option: 2
Enter mobile number with <Country Code Digits> followed by ENTER KEY:
0963598529
Enter the message format(0 for CDMA, 6 for GSM/WCDMA) followed by <Enter> key:
6
Enter the encoding scheme for message format GSM/WCDMA(0 for default 7Bit, 4 for 8 Bit, 8 for UCS2 Encoding ) followed by <Enter> key:
0
Enter the message to send followed by the <Enter> key
HELLO
Enter the SMS is Over IMS (0 for default Not Specify , 1 for SMS Not on IMS, 2 for SMS on IMS ) followed by <Enter> key:
1
Send SMS Successful
Hi Donald,
Thank you with your reply. I need SmsSetStorage function,but SMS_Application didn’t suport it …
Albert
