Ive tried to follow the QMI SDK to a T and unable to connect to the unit but not sure where im messing up
i built the SDK executable
loaded drivers
when i do the command it shows this in /var/log/user.log
Also do users use mmcli or qmicli
loaded drivers
I believe all pre-requisites prior to use all sierra sdk tools. Could you list down “/dev/q*” because all sierra sdk tools are referring to these devices.
The modem is configured for MBIM. It must be in QMI mode for the SDK. I believe this is covered by the SDK docs. Use AT!USBCOMP to change the configuration.
Actually i dont see anything showing ls /dev/q*
how do i submit the AT command to change it
do i do something like minicom into ttyUSB2 ?
Ohh just got in … learning ova here lOL never been in AT LOL
BUT when i do this
AT!USBCOMP
ERROR
RE-edit found out theres some sort aof ENTERCND LOL
Did you install and configure “GobiNet” and “GobiSerial” drivers as required by that SDK ? Based on you input that module is working fine on linux/ubuntu because I’ve the same on DELL E7240 running Ubuntu 17.04 and could get internet access. Without “GobiNet” and “GobiSerial” drivers, system would generate “/dev/cdc-wdm1” and “/dev/cdc-wdm2”.
pi@raspberrypi:~/sdk $ lsmod | grep -i gob
GobiSerial 10665 2
usbserial 29964 5 GobiSerial
GobiNet 104246 0
From that related documentation, please refer below statements.
3.3.1.
Host Setup
The Linux distribution may have in built drivers and applications that can interfere with SDK process’s
execution. The below Qualcomm drivers, if present, need to be black listed.
qcserial
qmi_wwan
Please black list them as below (example is for Ubuntu). Add the 2 entries to the
“/etc/modprobe.d/blacklist-modem.conf” file and restart the host
blacklist qcserial
blacklist qmi_wwan
is another application that can interfere with the SDK’s operation. Please remove it
and restart the host. Below example is for an Ubuntu PC:
“Modem Manager”
#sudo apt-get remove modemmanager
#sudo killall -9 modemmanager
#sudo reboot
I did do the blacklist in the way beggining
I did try out modemmanager but i i did a purge but i ll do a autoremove now .
i rebooted
but dmesg still showing it up at cdc_mbim
i still cant seem to get it its still showing cdc_mbim
[ 7.566736] GobiNet: 2017-01-04/SWI_2.40
[ 7.567593] usbcore: registered new interface driver GobiNet
[ 7.585035] usbcore: registered new interface driver cdc_ncm
[ 7.682117] usbcore: registered new interface driver cdc_wdm
[ 7.755037] usbcore: registered new interface driver usbserial
[ 7.755263] usbcore: registered new interface driver usbserial_generic
[ 7.755441] usbserial: USB Serial support registered for generic
[ 7.772723] usbcore: registered new interface driver GobiSerial
[ 7.772925] usbserial: USB Serial support registered for GobiSerial
[ 7.840900] cdc_mbim 1-1:1.12: cdc-wdm0: USB WDM device
[ 7.842646] cdc_mbim 1-1:1.12 wwan0: register 'cdc_mbim' at usb-20980000.usb-1, CDC MBIM, f2:a0:3e:5d:60:84
[ 7.906800] GobiSerial 1-1:1.0: GobiSerial converter detected
[ 7.912789] usbcore: registered new interface driver cdc_mbim
[ 7.913171] usb 1-1: GobiSerial converter now attached to ttyUSB0
[ 8.058356] GobiSerial 1-1:1.3: GobiSerial converter detected
[ 8.062743] usb 1-1: GobiSerial converter now attached to ttyUSB1
[ 8.086968] GobiSerial: 2017-01-04/SWI_2.27:GobiSerial
Have a good day. I’ve MC7455 module installed on DELL E7240 running Ubuntu 17.04 where result as below:
Model: MC7455
Revision: SWI9X30C_02.24.03.00 r6978 CARMD-EV-FRMWR2 2017/03/02 13:36:45
MEID: 35907206065989
IMEI: 359072060659899
IMEI SV: 9
FSN: LQ708248800410
+GCAP: +CGSM
at!entercnd=“A710”
at!usbcomp?
Config Index: 1
Config Type: 1 (Generic)
Interface bitmask: 0000050D (diag,nmea,modem,rmnet0,rmnet1)
You could change “USBCOMP” of your module to “1,1,50D” and reset that module “at!reset” or just reboot your machine and should be shown as below:
zabo5515@zabo5515-E7240:~$ dmesg | grep -i qmi_wwan
[ 3.024236] qmi_wwan 2-7:1.8: cdc-wdm1: USB WDM device
[ 3.024669] qmi_wwan 2-7:1.8 wwan0: register ‘qmi_wwan’ at usb-0000:00:14.0-7, WWAN/QMI device, 8e:c0:45:2f:c2:73
[ 3.025049] qmi_wwan 2-7:1.10: cdc-wdm2: USB WDM device
[ 3.025922] qmi_wwan 2-7:1.10 wwan1: register ‘qmi_wwan’ at usb-0000:00:14.0-7, WWAN/QMI device, 8e:c0:45:2f:c2:73
[ 3.025969] usbcore: registered new interface driver qmi_wwan
[ 3.297890] qmi_wwan 2-7:1.8 wwp0s20u7i8: renamed from wwan0
[ 3.315593] qmi_wwan 2-7:1.10 wwp0s20u7i10: renamed from wwan1
should i remove the qmi_wwan in the modprobe.d/blacklist-modem-conf then
ill try it hehe
Above “qcqmi0 & qcqmi1” are used by that Sierra SDK tools.
OH cool SWEEEEEEET thanks i think im getting some success with qmi now.
this is rasberry Pi zero Wireless too hehe
pi@raspberrypi:~/sdk $ sudo ./SampleApps/Connection_Manager/bin/connectionmgrhostarmv6l ./build/bin/hostarmv6l/slqssdk 0
Instance ID :0
Session StateV4:1
Session StateV6:1
Instance ID :1
Session StateV4:1
Session StateV6:1
Please select one of the following options or press to exit:
