Hi, I want to use qmi_wwan and qmicli with WP76 module, but I saw the following that no response on QMI message. Any idea?
owner@ubuntu:~$ lsusb -t
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 5000M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/7p, 12M
|__ Port 1: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 3, If 0, Class=Hub, Driver=hub/7p, 480M
|__ Port 1: Dev 14, If 0, Class=Vendor Specific Class, Driver=qcserial, 480M
|__ Port 1: Dev 14, If 2, Class=Vendor Specific Class, Driver=qcserial, 480M
|__ Port 1: Dev 14, If 3, Class=Vendor Specific Class, Driver=qcserial, 480M
|__ Port 1: Dev 14, If 8, Class=Vendor Specific Class, Driver=qmi_wwan, 480M
|__ Port 1: Dev 14, If 19, Class=Communications, Driver=cdc_ether, 480M
|__ Port 1: Dev 14, If 20, Class=CDC Data, Driver=cdc_ether, 480M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
|__ Port 2: Dev 2, If 0, Class=Hub, Driver=hub/7p, 12M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/6p, 480M
owner@ubuntu:~$ sudo qmicli --device=/dev/cdc-wdm0 --device-open-proxy --dms-get-manufacturer -v
[09 Mar 2021, 16:32:41] [Debug] [/dev/cdc-wdm0] Opening device with flags 'proxy, auto'...
[09 Mar 2021, 16:32:41] [Debug] [/dev/cdc-wdm0] loaded driver of cdc-wdm port: qmi_wwan
[09 Mar 2021, 16:32:41] [Debug] [/dev/cdc-wdm0] automatically selecting QMI mode
[09 Mar 2021, 16:32:41] [Debug] cannot connect to proxy: Could not connect: Connection refused
[09 Mar 2021, 16:32:41] [Debug] spawning new qmi-proxy (try 1)...
[09 Mar 2021, 16:32:41] [Debug] [/dev/cdc-wdm0] sent message...
<<<<<< RAW:
<<<<<< length = 28
<<<<<< data = 01:1B:00:00:00:00:00:01:00:FF:10:00:01:0D:00:2F:64:65:76:2F:63:64:63:2D:77:64:6D:30
[09 Mar 2021, 16:32:41] [Debug] [/dev/cdc-wdm0] sent generic request (translated)...
<<<<<< QMUX:
<<<<<< length = 27
<<<<<< flags = 0x00
<<<<<< service = "ctl"
<<<<<< client = 0
<<<<<< QMI:
<<<<<< flags = "none"
<<<<<< transaction = 1
<<<<<< tlv_length = 16
<<<<<< message = "Internal Proxy Open" (0xFF00)
<<<<<< TLV:
<<<<<< type = "Device Path" (0x01)
<<<<<< length = 13
<<<<<< value = 2F:64:65:76:2F:63:64:63:2D:77:64:6D:30
<<<<<< translated = /dev/cdc-wdm0
[09 Mar 2021, 16:32:41] [Debug] [/dev/cdc-wdm0] received message...
<<<<<< RAW:
<<<<<< length = 19
<<<<<< data = 01:12:00:80:00:00:01:01:00:FF:07:00:02:04:00:00:00:00:00
[09 Mar 2021, 16:32:41] [Debug] [/dev/cdc-wdm0] received generic response (translated)...
<<<<<< QMUX:
<<<<<< length = 18
<<<<<< flags = 0x80
<<<<<< client = 0
<<<<<< QMI:
<<<<<< flags = "response"
<<<<<< tlv_length = 7
<<<<<< TLV:
<<<<<< type = "Result" (0x02)
<<<<<< length = 4
<<<<<< value = 00:00:00:00
<<<<<< translated = SUCCESS
[09 Mar 2021, 16:32:41] [Debug] QMI Device at '/dev/cdc-wdm0' ready
[09 Mar 2021, 16:32:41] [Debug] [/dev/cdc-wdm0] Assuming service 'dms' is supported...
[09 Mar 2021, 16:32:41] [Debug] [/dev/cdc-wdm0] Allocating new client ID...
<<<<<< RAW:
<<<<<< length = 16
<<<<<< data = 01:0F:00:00:00:00:00:02:22:00:04:00:01:01:00:02
<<<<<< QMUX:
<<<<<< length = 15
<<<<<< flags = 0x00
<<<<<< client = 0
<<<<<< QMI:
<<<<<< transaction = 2
<<<<<< tlv_length = 4
<<<<<< message = "Allocate CID" (0x0022)
<<<<<< TLV:
<<<<<< type = "Service" (0x01)
<<<<<< length = 1
<<<<<< value = 02
<<<<<< translated = dms
error: couldn't create client for the 'dms' service: CID allocation failed in the CTL client: Transaction timed out
owner@ubuntu:~$
