Hello!
I am able to use screen to communicate and run AT commands. I even have an ip address as verified by at+cgpaddr. When using qmicli to communicate any and all commands involving the modem fail (shown below). My goal is to be able to use the wwan0 interface to ping (currently not working).
I’m not sure how to debug this or figure out what is being sent from the qmicli utility. Any insight would be very helpful.
sudo qmicli --device=/dev/cdc-wdm0 --get-expected-data-format
802-3
qmicli --device=/dev/cdc-wdm0 --device-open-proxy --wda-get-data-format
[04 Nov 2022, 21:57:09] -Warning ** Cannot read from istream: connection broken
error: couldn't open the QmiDevice: Cannot write message: Error sending data: Broken pipe
sudo qmicli -d /dev/cdc-wdm0 --wda-get-data-format
error: couldn't create client for the 'wda' service: CID allocation failed in the CTL client: Transaction timed out
Thanks Jyijyi,
I decided to use openWRT, so this became a little easier. I installed kmod-usb-serial-qualcomm and things seem to be okay on the linux side of things.On the modem however, even though the modem is attached to the network (at+cgpaddr gives an ip address for pdp context: 1), I get the following:
Yes, On Ubuntu everything worked well. I was able to ping google.com after following your very useful guide. On openWRT I did not install MBPL drivers, but it looks like the qmi utility (uqmi) can talk to the modem.
At this point I’m more concerned about not being able to get an OK from AT!SCACT=1,1 even though I’ve been assigned an IP from my provider (AT&T for now).
Can you see anything wrong?
at
ati3
Model: EM7565
Revision: SWI9X50C_01.14.13.00 883709 jenkins 2022/01/05 07:08:35
IMEI: 359260080929398
IMEI SV: 14
FSN: UF203303520410
+GCAP: +CGSM
at+ccid?
+CCID: 89010303300092183574
at+cimi
310030009218357
at!entercnd="A710"
at!sku?
SKU: 1103520
AT!HWID?
Revision: 1.0
AT!IMPREF?
!IMPREF:
preferred fw version: 01.14.13.00
preferred config name: GENERIC_002.048_000
preferred subpri index: 000
current fw version: 01.14.13.00
current carrier name: GENERIC
current config name: GENERIC_002.048_000
current subpri index: 000
AT!PRIID?
PRI Part Number: 9907344
Revision: 002.006
Customer: Generic-M2M
Carrier PRI: 9999999_9907259_SWI9X50C_01.14.13.00_00_GENERIC_002.048_000
Carrier PRI: 9999999_9907258_SWI9X50C_01.07.02.00_00_ATT_002.008_012
Carrier PRI: 9999999_9908609_SWI9X50C_01.09.04.00_00_DOCOMO_002.015_002
Carrier PRI: 9999999_9908608_SWI9X50C_01.09.04.00_00_KDDI_002.018_002
Carrier PRI: 9999999_9908789_SWI9X50C_01.08.04.00_00_SIERRA_002.001_002
Carrier PRI: 9999999_9908607_SWI9X50C_01.09.04.00_00_SOFTBANK_002.017_002
Carrier PRI: 9999999_9909446_SWI9X50C_01.08.04.00_00_SPRINT_000.001_003
Carrier PRI: 9999999_9908610_SWI9X50C_01.11.00.00_00_TELSTRA_002.007_002
Carrier PRI: 9999999_9909335_SWI9X50C_01.07.02.00_00_TELUS_001.000_002
Carrier PRI: 9999999_9907257_SWI9X50C_01.08.04.00_00_VERIZON_002.015_006
AT!USBCOMP?
Config Index: 1
Config Type: 3 (Generic)
Interface bitmask: 0000010D (diag,nmea,modem,rmnet0)
AT!GSTATUS?
!GSTATUS:
Current Time: 2895 Temperature: 24
Reset Counter: 18 Mode: ONLINE
LTE band: B2 LTE bw: 20 MHz
LTE Rx chan: 700 LTE Tx chan: 18700
LTE SCC1 state:NOT ASSIGNED
LTE SCC2 state:NOT ASSIGNED
LTE SCC3 state:NOT ASSIGNED
LTE SCC4 state:NOT ASSIGNED
RRC state: RRC Idle
IMS reg state: No Srv
PCC RxM RSSI: -47 PCC RxM RSRP: -80
PCC RxD RSSI: -47 PCC RxD RSRP: -80
Tx Power: -- TAC: 0407 (1031)
RSRQ (dB): -12.4 Cell ID: 01028108 (16941320)
SINR (dB): 21.6
AT+COPS?
+COPS: 0,0,"AT&T",7
AT+CGDCONT?
+CGDCONT: 1,"IPV4V6","","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0
AT!UIMS?
!UIMS: 0
AT!BAND?
Index, Name, GW Band Mask L Band Mask 1 TDS Band M ask L Band Mask 2 L Band Mask 3 L Band Mask 4
00, All bands 100600000EC00000 00002100BA0E19DF 000000000000 0000 0000000000000002 0000000000000000 0000000000000000
AT+CGDCONT=1,"IPV4V6","broadband"
at
at+cfun = 1
at+cfun=0
at+cfun=1
at+creg?
+CREG: 0,1
at+cgatt?
+CGATT: 1
at+cgpaddr
+CGPADDR: 1,10.179.10.193
ok, MBPL was unnecessary here as those drivers are included in the openWRT kernel under the opkg names
kmod-usb-serial-qualcomm, kmod-usb-net-qmi-wwan, qmi-utils. I went over your guide again and I can ping through the wwan0 interface. Thanks for your help.
