Hi.
We are running Linux 4.4.32 with qmi_wwan/cdc-wdm0 drivers , and Sierra Wireless EM7455 Qualcomm® Snapdragon™ X7 LTE-A LTE modem.
Everything works, until some packets are exchanged, and RX stucks. in ifconfig, only “RX errors” increasing.
After a while, kernel complains:
[ 1959.468676] NETDEV WATCHDOG: lte0 (qmi_wwan): transmit queue 0 timed out
and TX errors start increasing only.
Only solution to restore traffic is to reload system.
Seems what causes the problem is first received fragmented packet. Till then RX and TX works normally (with non-fragmented packets).
Any suggestions ?
We worked with slightly older 74XX modems without any problem.
Here is details for the modem:
[root@lanner-1510 ~]# lsusb -v -d 1199:9071
Bus 002 Device 002: ID 1199:9071 Sierra Wireless, Inc.
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 9
idVendor 0x1199 Sierra Wireless, Inc.
idProduct 0x9071
bcdDevice 0.06
iManufacturer 1 Sierra Wireless, Incorporated
iProduct 2 Sierra Wireless EM7455 Qualcomm® Snapdragon™ X7 LTE-A
iSerial 3 LF81757479041022
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 226
bNumInterfaces 4
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 126mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 255 Vendor Specific Protocol
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0400 1x 1024 bytes
bInterval 0
bMaxBurst 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 3
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 0
** UNRECOGNIZED: 05 24 00 10 01
** UNRECOGNIZED: 05 24 01 00 00
** UNRECOGNIZED: 04 24 02 02
** UNRECOGNIZED: 05 24 06 00 00
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x000a 1x 10 bytes
bInterval 9
bMaxBurst 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 0
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 3
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x85 EP 5 IN
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 9
bMaxBurst 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 0
bLength 9
bDescriptorType 4
bInterfaceNumber 8
bAlternateSetting 0
bNumEndpoints 3
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x87 EP 7 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 9
bMaxBurst 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x86 EP 6 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x04 EP 4 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 0
Binary Object Store Descriptor:
bLength 5
bDescriptorType 15
wTotalLength 22
bNumDeviceCaps 2
USB 2.0 Extension Device Capability:
bLength 7
bDescriptorType 16
bDevCapabilityType 2
bmAttributes 0x00000000
(Missing must-be-set LPM bit!)
SuperSpeed USB Device Capability:
bLength 10
bDescriptorType 16
bDevCapabilityType 3
bmAttributes 0x00
wSpeedsSupported 0x000f
Device can operate at Low Speed (1Mbps)
Device can operate at Full Speed (12Mbps)
Device can operate at High Speed (480Mbps)
Device can operate at SuperSpeed (5Gbps)
bFunctionalitySupport 1
Lowest fully-functional device speed is Full Speed (12Mbps)
bU1DevExitLat 1 micro seconds
bU2DevExitLat 500 micro seconds
can’t get debug descriptor: Resource temporarily unavailable
Device Status: 0x0000
(Bus Powered)
RAW Paste Data
Thank you.
martin.
