Rc7630 couldn't get IP address under ubunut Linux(RC7630)
RC7630 couldn’t get IP address under embedded LINUX.
Please check if my udhcpd setting is correct.
Test condition
embedded linux
kernel : 5.10.168
model : RC7630
AT
ATI
Model: RC7630
Revision: SWI9X07H_00.09.10.00 85890e jenkins 2023/09/25 03:16:56
IMEI: 350867110107792
IMEI SV: 29
FSN: 161454504005A0
+GCAP: +CGSM
AT!GSTATUS?
!GSTATUS:
Current Time: 1056 Temperature: 31
Reset Counter: 1 Mode: ONLINE
IMS reg state: NOT REGISTERED IMS mode: Normal
IMS Srv State: NO SMS,NO VoIP
LTE band: B1 LTE bw: 15 MHz
LTE Rx chan: 275 LTE Tx chan: 18275
LTE CA state: INACTIVE
RRC state: RRC Idle
PCC RxM RSSI: -64 RSRP (dBm): -91
PCC RxD RSSI: -95 RSRP (dBm): -125
Tx Power: – TAC: 1904 (6404)
RSRQ (dB): -9 Cell ID: 0013F963 (1309027)
SINR (dB): 11.4
AT+CREG?
+CREG: 1,5
AT+CGREG?
+CGREG: 1,5
AT+CEREG?
+CEREG: 1,5
AT+CGDCONT?
+CGDCONT: 1,“IP”,“internet.swir”,“0.0.0.0”,0,0,0,0
+CGDCONT: 2,“IPV4V6”,“ims”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 3,“IPV4V6”,“sos”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,1
AT+CGPADDR=1
+CGPADDR: 1,100.82.144.50
AT+COPS?
+COPS: 0,0,“SKTelecom Sierra Wireless”,7
AT+CFUN=0
+CREG: 0
+CGREG: 0
+CEREG: 0
AT+CFUN=1
+CREG: 2
+CGREG: 2
+CEREG: 2
+CREG: 5
+CGREG: 5
+CEREG: 5
AT+CGACT=1,1
AT!BAND?
Index, Name
00, All bands
AT*PSRDBS?
*PSRDBS: 189006479360
AT+CSQ
+CSQ: 27,99
AT+CESQ
+CESQ: 99,99,255,255,13,50
AT+CGATT?
+CGATT: 1
didn’t you already get the IP address here?
AT+CGPADDR=1
i get the new SDK R41
and i compile and run
i get a log below
please, let me get a way to prove this problem
NVTEVM login: root
NVTEVM Linux shell…
root@NVTEVM:~$
root@NVTEVM:~$
root@NVTEVM:~$ microcom -s 115200 -d 10 /dev/ttyUSB2\
^C
AT+CGDCONT=1,“IP”,“cmhk”
AT+CGDCONT?
+CGDCONT: 1,“IP”,“cmhk”,“0.0.0.0”,0,0,0,0
AT+CGACT=0,1
ERROR
AT+CGACT=1,1
AT+CGPADDR=1
+CGPADDR: 1,10.170.81.161
root@NVTEVM:/mnt/app$ ./lite-qmi-connection-managerarm
lite-qmi-connection-manager v1.0.2409.0
Open transport “/dev/cdc-wdm0” on USB device in QMI mode
Interface id: 0x8
root@NVTEVM:$ ifconfig -a
eth0 Link encap:Ethernet HWaddr DA:D6:87:A1:7C:E1
inet addr:192.168.0.3 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::d8d6:87ff:fea1:7ce1/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:34456 errors:0 dropped:1361 overruns:0 frame:0
TX packets:11 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:3419455 (3.2 MiB) TX bytes:946 (946.0 B)
Interrupt:27
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
sit0 Link encap:IPv6-in-IPv4
NOARP MTU:1480 Metric:1
teql0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
-00
NOARP MTU:1500 Metric:1
wwan0 Link encap:Ethernet HWaddr 2E:64:27:84:1A:99
BROADCAST MULTICAST MTU:1500 Metric:1
Interface id: 0x8
Transport callback is invoked, type: 1, value: 0.
CtlService_InitializeEx failed
Interface id: 0x8
Network interface: wwan0
Device interface: RmNet
Set uplink/downlink data aggregation protocol 5
Model: RC7630
Device Power Status: 0 - Online
HomeNetwork: CMHK
Network Selection Preference: auto
SessionStatus (0:ipv4): Disconnected
SessionStatus (1:ipv6): Disconnected
SessionStatus (2:ipv4): Disconnected
SessionStatus (3:ipv6): Disconnected
SessionStatus (4:ipv4): Disconnected
SessionStatus (5:ipv6): Disconnected
SessionStatus (6:ipv4): Disconnected
SessionStatus (7:ipv6): Disconnected
Auto-ping check on connection: enabled
Routing table update on connection: enabled
Please select one of the following options or press ‘q’ to exit:
1.  start a single-PDN data session
2.  Start one connection of a multi-PDN data session
3.  Stop one connection
4.  Stop all active connections
5.  Display all profiles on the device
6.  Display one profile on the device
7.  Create a profile on the device
8.  Modify an existing profile on the device
9.  Delete a profile from the device
10. Scan available networks
11. Enable QOS Event
12. Disable QOS Event
13. Request QOS Expanded
14. Get QOS Information
15. QOS Indication Register
16. Read QOS Data Statistics (SWIQOS)
17. Read QOS Extra APN Parameters (SWIQOS)
18. Get Packet Statistics
19. Get Current Channel Rate
20. Toggle pinging on connection
21. Toggle routing table update on connection
22. Get loopback
23. Set loopback
24. Get data format
25. Set data format
26. Enable/disable WDS event report indication
27. Enable/disable keep data session alive
28. Get delegated IPv6 prefix
29. Remove delegated IPv6 prefix
(q)uit to exit:
2
Please enter Network selection preference (0: Auto (default), 1: Manual) (up to
3 Characters), or press to use default value: 0
Please enter Connect via 0: existing profile (default) or 1: explicit APN (up to
ID PDPType IPAddress PrimaryDNS SecondaryDNS Auth Pro
fileName APNName UserName IPv6PrefixDele
*1 0 0.0.0.0 0.0.0.0 0.0.0.0 0
cmhk disabled
Please enter a profile id (1-42) (up to 4 Characters), or press to exit:
root@NVTEVM:/mnt/app$ ifconfig -a
\eth0 Link encap:Ethernet HWaddr DA:D6:87:A1:7C:E1
inet addr:192.168.37.225 Bcast:192.168.37.255 Mask:255.255.255.0
RX packets:762761 errors:0 dropped:28909 overruns:0 frame:0
TX packets:618 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:77977011 (74.3 MiB) TX bytes:48643 (47.5 KiB)
Interrupt:27
qmimux0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
-00
POINTOPOINT NOARP MULTICAST MTU:1500 Metric:1
qmimux1 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
-00
qmimux2 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
-00
qmimux3 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
-00
-00
wwan0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
-00
I ran lite-qmi-connection-manager.
However, it is not actually connected to the rc7630 module.
However, unlike when testing previously, when i run the ifconfig -a command, the log that was replied to just before is displayed.
The curious thing is that qmimux0, qmimux1, qmimux2, and qmimux3 are displayed, but no values ​​are actually assigned.
while looking for the cause, I found out that qmicli was necessary, so I compiled and used qmicli.
The result is the log below
Please tell us the meaning of the error in the log below.
error: couldn’t start network: QMI protocol error (14): ‘CallFailed’
If you have a solution please let me know
root@NVTEVM:/mnt/app$ root@NVTEVM:/mnt/app$ qmicli --verbose --device=/dev/cdc-wdm0 --dms-get-ids
[01 Jan 1970, 04:45:47] [Debug] [/dev/cdc-wdm0] Opening device with flags ‘auto’
[01 Jan 1970, 04:45:47] [Debug] [/dev/cdc-wdm0] created endpoint
[01 Jan 1970, 04:45:47] [Debug] QMI Device at ‘/dev/cdc-wdm0’ ready
[01 Jan 1970, 04:45:47] [Debug] [/dev/cdc-wdm0] Assuming service ‘dms’ is suppor
ted…
[01 Jan 1970, 04:45:47] [Debug] [/dev/cdc-wdm0] Allocating new client ID…
[01 Jan 1970, 04:45:47] [Debug] [/dev/cdc-wdm0] Sent message…
<<<<<< RAW:
<<<<<< length = 16
<<<<<< data = 01:0F:00:00:00:00:00:01:22:00:04:00:01:01:00:02
[01 Jan 1970, 04:45:47] [Debug] [/dev/cdc-wdm0] Sent generic request (translated
<<<<<< QMUX:
<<<<<< length = 15
<<<<<< flags = 0x00
<<<<<< service = “ctl”
<<<<<< client = 0
<<<<<< QMI:
<<<<<< flags = “none”
<<<<<< transaction = 1
<<<<<< tlv_length = 4
<<<<<< message = “Allocate CID” (0x0022)
<<<<<< TLV:
<<<<<< type = “Service” (0x01)
<<<<<< length = 1
<<<<<< value = 02
<<<<<< translated = dms
[01 Jan 1970, 04:45:47] [Debug] [/dev/cdc-wdm0] Received message…
<<<<<< RAW:
<<<<<< length = 24
<<<<<< data = 01:17:00:80:00:00:01:01:22:00:0C:00:02:04:00:00:00:00:00:01:02
:00:02:02
[01 Jan 1970, 04:45:47] [Debug] [/dev/cdc-wdm0] Received generic response (trans
lated)…
<<<<<< QMUX:
<<<<<< length = 23
<<<<<< flags = 0x80
<<<<<< client = 0
<<<<<< QMI:
<<<<<< flags = “response”
<<<<<< tlv_length = 12
<<<<<< TLV:
<<<<<< type = “Result” (0x02)
<<<<<< length = 4
<<<<<< value = 00:00:00:00
<<<<<< translated = SUCCESS
<<<<<< TLV:
<<<<<< type = “Allocation Info” (0x01)
<<<<<< length = 2
<<<<<< value = 02:02
<<<<<< translated = [ service = ‘dms’ cid = ‘2’ ]
[01 Jan 1970, 04:45:47] [Debug] [/dev/cdc-wdm0] Registered ‘dms’ (version unknow
n) client with ID ‘2’
[01 Jan 1970, 04:45:47] [Debug] Asynchronously getting IDs…
<<<<<< RAW:
<<<<<< length = 13
<<<<<< data = 01:0C:00:00:02:02:00:01:00:25:00:00:00
<<<<<< QMUX:
<<<<<< length = 12
<<<<<< flags = 0x00
<<<<<< service = “dms”
<<<<<< client = 2
<<<<<< QMI:
<<<<<< tlv_length = 0
<<<<<< message = “Get IDs” (0x0025)
<<<<<< RAW:
<<<<<< length = 47
<<<<<< data = 01:2E:00:80:02:02:02:01:00:25:00:22:00:02:04:00:00:00:00:00:10
:01:00:30:11:0F:00:33:35:30:38:36:37:31:31:30:31:30:36:36:39:35:13:02:00:31:37
lated)…
<<<<<< QMUX:
<<<<<< length = 46
<<<<<< flags = 0x80
<<<<<< client = 2
<<<<<< QMI:
<<<<<< tlv_length = 34
<<<<<< TLV:
<<<<<< length = 4
<<<<<< TLV:
<<<<<< type = “Esn” (0x10)
<<<<<< length = 1
<<<<<< value = 30
<<<<<< translated = 0
<<<<<< TLV:
<<<<<< type = “Imei” (0x11)
<<<<<< length = 15
<<<<<< value = 33:35:30:38:36:37:31:31:30:31:30:36:36:39:35
<<<<<< translated = 350867110106695
<<<<<< TLV:
<<<<<< type = “Imei Software Version” (0x13)
<<<<<< length = 2
<<<<<< value = 31:37
<<<<<< translated = 17
[/dev/cdc-wdm0] Device IDs retrieved:
ESN: ‘0’
IMEI: ‘350867110106695’
MEID: ‘unknown’
IMEI SV: ‘17’
[01 Jan 1970, 04:45:47] [Debug] [/dev/cdc-wdm0] Releasing ‘dms’ client with flag
s ‘release-cid’…
[01 Jan 1970, 04:45:47] [Debug] [/dev/cdc-wdm0] Unregistered ‘dms’ client with I
D ‘2’
<<<<<< RAW:
<<<<<< length = 17
<<<<<< data = 01:10:00:00:00:00:00:02:23:00:05:00:01:02:00:02:02
<<<<<< QMUX:
<<<<<< length = 16
<<<<<< flags = 0x00
<<<<<< client = 0
<<<<<< QMI:
<<<<<< transaction = 2
<<<<<< tlv_length = 5
<<<<<< message = “Release CID” (0x0023)
<<<<<< TLV:
<<<<<< type = “Release Info” (0x01)
<<<<<< length = 2
<<<<<< RAW:
<<<<<< length = 24
<<<<<< data = 01:17:00:80:00:00:01:02:23:00:0C:00:02:04:00:00:00:00:00:01:02
:00:02:02
lated)…
<<<<<< QMUX:
<<<<<< length = 23
<<<<<< flags = 0x80
<<<<<< client = 0
<<<<<< QMI:
<<<<<< TLV:
<<<<<< length = 4
<<<<<< TLV:
<<<<<< length = 2
[01 Jan 1970, 04:45:47] [Debug] Client released
[01 Jan 1970, 04:45:47] [Debug] Closed
qmicli --device=/dev/cdc-wdm0 --dms-get-operating-mode
[/dev/cdc-wdm0] Operating mode retrieved:
Mode: ‘online’
HW restricted: ‘no’
root@NVTEVM:/usr/lib$
root@NVTEVM:/usr/lib$ qmicli --device=/dev/cdc-wdm0 --get-wwan-iface
wwan0
root@NVTEVM:/usr/lib$ qmicli --device=/dev/cdc-wdm0 --wda-get-data-format
[/dev/cdc-wdm0] Successfully got data format
                   QoS flow header: no
               Link layer protocol: 'raw-ip'
  Uplink data aggregation protocol: 'qmap'
Downlink data aggregation protocol: 'qmap'
                     NDP signature: '0'
Downlink data aggregation max datagrams: '10'
Downlink data aggregation max size: '4096'
root@NVTEVM:/usr/lib$ qmicli --device=/dev/cdc-wdm0 --wds-start-network=“ip-type
=4,apn=your_apn” --client-no-release-cid
call end reason (1018): gsm-wcdma-option-unsubscribed
verbose call end reason (6,33): [3gpp] option-unsubscribed
[/dev/cdc-wdm0] Client ID not released:
Service: ‘wds’
CID: ‘11’
root@NVTEVM:/usr/lib$ udhcpc -i wwan0
udhcpc: started, v1.36.0
1 Setting IP address 192.168.0.3 on wwan0
udhcpc: broadcasting discover
^C
root@NVTEVM:/usr/lib$ qmicli --device=/dev/cdc-wdm0 --wds-get-packet-service-sta
tus
[/dev/cdc-wdm0] Connection status: ‘disconnected’
I can run the MBPL connection manager application with RC7620:
owner@ubuntu:~/QMI/MBPL/MBPL_SDK_R30_ENG6-lite.src/MBPL_SDK_R30_ENG6-lite.src/SampleApps/lite-qmi-connection-manager$ sudo ./bin/lite-qmi-connection-managerhostx86_64
lite-qmi-connection-manager v1.0.2211.0
Open transport "/dev/cdc-wdm0" on USB device in QMI mode
Interface id: 8
QMAP enabled
Model: RC7620
HomeNetwork: CMHK
Please select one of the following options or press 'q' to exit:
    11.	Lock PCI
    12.	Disable PCI locking
    13.	Get PCI locking
    14.	Enable QOS Event
    15.	Disable QOS Event
    16.	Request QOS Expanded
    17.	Get QOS Information
    18.	QOS Indication Register
    19.	Read QOS Data Statistics (SWIQOS)
    20.	Read QOS Extra APN Parameters (SWIQOS)
    21.	Get Packet Statistics
    22.	Get Current Channel Rate
    23.	Toggle pinging on connection
    24.	Toggle routing table update on connection
    27.	Enable QMAP
    28.	Disable QMAP
    29.	Enable/disable WDS event report indication
    30.	Enable/disable keep data session alive
    (q)uit to exit:
1
Please enter Network selection preference (0: Auto (default), 1: Manual) (up to 3 Characters), or press <Enter> to use default value:
Please enter Connect via 0: existing profile (default) or 1: explicit APN (up to 3 Characters), or press <Enter> to use default value:
ID PDPType IPAddress           PrimaryDNS          SecondaryDNS        Auth ProfileName         APNName             UserName
1  0       0.0.0.0             0.0.0.0             0.0.0.0             0                        CMHK
2  3       0.0.0.0             0.0.0.0             0.0.0.0             0                        ims
3  3       0.0.0.0             0.0.0.0             0.0.0.0             0                        sos
Please enter a profile id (1-42) (up to 4 Characters), or press <Enter> to exit: 1
1: IPV4 (default)
2: IPV6
3: IPV4V6
Please enter IP family preference for the call (up to 3 Characters), or press <Enter> to use default value:
WDS[0] BindMuxID 1 returns 0
WDS[0] setIPFamily preference 4 returns 0
Starting data session via profile 1
WDS[0] IPv4 data session started successfully for Profile ID: 1
<< receiving WDS_PKT_STATUS_IND
WDS IND: msgid 0x22, type:4
[unpack_wds_SLQSSetPacketSrvStatusCallback]
	Packet Service 0 Status: 0x2, Reconfig required: 0
	IP Family: 4
	Technology: 0x8004
	Bearer ID: 0x5
SessionStatus (0:ipv4): Connected
SetAdaptorMtu(qmimux0:4) mtu 1500
SetAdaptorMtu(wwan0:3) mtu 1500
Up adaptor wwan0(3)
Up adaptor qmimux0(4)
SetAdaptorAddress(family 2): ip addr add 10.99.157.195:29 dev qmimux0(4)
IsAdaptorUp - Adaptor wwan0 is up
IsAdaptorUp - Adaptor qmimux0 is up
SetRoute(family 2): route add 0.0.0.0:0 dev qmimux0(4) gw 0.0.0.0
PING 8.8.8.8 56 bytes data in ICMP packets.
64 bytes from 8.8.8.8 icmp_seq=1 ttl=58 rtt=4001.000 ms
64 bytes from 8.8.8.8 icmp_seq=2 ttl=58 rtt=3001.000 ms
64 bytes from 8.8.8.8 icmp_seq=3 ttl=58 rtt=2000.000 ms
64 bytes from 8.8.8.8 icmp_seq=4 ttl=58 rtt=1000.000 ms
--------------------PING statistics-------------------
4 packets transmitted, 4 received , %0 lost
After that I can ping google server via qmimux0 interface:
owner@ubuntu:~$ ping 8.8.8.8 -I qmimux0
PING 8.8.8.8 (8.8.8.8) from 10.99.157.195 qmimux0: 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=58 time=133 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=58 time=17.2 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=58 time=24.0 ms
I can also start the network connection by qmicli in Ubuntu 18:
owner@ubuntu:~/QMI/MBPL/MBPL_SDK_R30_ENG6-lite.src/MBPL_SDK_R30_ENG6-lite.src/SampleApps/lite-qmi-connection-manager$ sudo qmi-network /dev/cdc-wdm0 start
Loading profile at /etc/qmi-network.conf...
    APN: CMHK
    APN user: unset
    APN password: unset
    qmi-proxy: no
Checking data format with 'qmicli -d /dev/cdc-wdm0 --wda-get-data-format '...
Device link layer protocol retrieved: raw-ip
Getting expected data format with 'qmicli -d /dev/cdc-wdm0 --get-expected-data-format'...
Expected link layer protocol retrieved: 802-3
Updating kernel link layer protocol with 'qmicli -d /dev/cdc-wdm0 --set-expected-data-format=raw-ip'...
Kernel link layer protocol updated
Starting network with 'qmicli -d /dev/cdc-wdm0 --wds-start-network=apn='CMHK'  --client-no-release-cid '...
Saving state at /tmp/qmi-network-state-cdc-wdm0... (CID: 3)
Saving state at /tmp/qmi-network-state-cdc-wdm0... (PDH: 2248177728)
Network started successfully
owner@ubuntu:~/QMI/MBPL/MBPL_SDK_R30_ENG6-lite.src/MBPL_SDK_R30_ENG6-lite.src/SampleApps/lite-qmi-connection-manager$ ping 8.8.8.8 -I wwan0
connect: Network is unreachable
owner@ubuntu:~/QMI/MBPL/MBPL_SDK_R30_ENG6-lite.src/MBPL_SDK_R30_ENG6-lite.src/SampleApps/lite-qmi-connection-manager$ sudo udhcpc -i wwan0
udhcpc: started, v1.27.2
udhcpc: sending discover
udhcpc: sending select for 10.98.52.161
udhcpc: lease of 10.98.52.161 obtained, lease time 7200
PING 8.8.8.8 (8.8.8.8) from 10.98.52.161 wwan0: 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=117 time=99.4 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=117 time=35.6 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=117 time=29.6 ms
Lastly I have also followed the link below to establish data connection with AT!SCACT.
It is working fine on my Ubuntu 18:
ping command does not go out
root@NVTEVM:/mnt/app$ qmicli --device=/dev/cdc-wdm0 --wds-get-current-settings
error: couldn’t get current settings: QMI protocol error (15): ‘OutOfCall’
root@NVTEVM:/mnt/app$ qmicli --device=/dev/cdc-wdm0 --wds-start-network=“ip-type
=4,apn=cmhk” --client-no-release-cid
[/dev/cdc-wdm0] Network started
Packet data handle: ‘2247487600’
Service: ‘wds’
CID: ‘12’
[/dev/cdc-wdm0] Current settings retrieved:
IP Family: IPv4
IPv4 address: 10.170.123.214
IPv4 subnet mask: 255.255.255.252
IPv4 gateway address: 10.170.123.213
IPv4 primary DNS: 223.119.47.220
IPv4 secondary DNS: 223.119.30.220
MTU: 1440
Domains: none
root@NVTEVM:/mnt/app$ vi /etc/resolv.conf
nameserver 223.119.47.220
nameserver 223.119.30.220
root@NVTEVM:/mnt/app$ ping -I wwan0 8.8.8.8
PING 8.8.8.8 (8.8.8.8): 56 data bytes
then have you tried other method like AT!SCACT or connection manager application in MBPL?
Also have you tried qmi-network and udhcpc?
i got MBPL SDK R41 from sierra
and i compiled lite-qmi-connection-manager sample and ran it
i also applied udhcpc
then what are the result of using the followings?
  1. qmi-network and udhcpc
  2. AT!SCACT
  3. connection manager application
Please paste the log here
  1. connection manager application
    Before using the connection manager, I thought I had already activated it with the AT command AT+CGACT=1,1, but communication did not work well.
    So I used a connection manager application.
NVTEVM login: root
NVTEVM Linux shell…
AT+CGDCONT?
AT+CGACT=0,1
ERROR
AT+CGACT=1,1
AT+CGPADDR=1
+CGPADDR: 1,10.112.252.102
after using connection manager application
login[527]: root login on ‘pts/0’
eth0 Link encap:Ethernet HWaddr 82:4B:B2:29:0A:FC
inet6 addr: fe80::804b:b2ff:fe29:afc/64 Scope:Link
RX packets:107151 errors:0 dropped:4226 overruns:0 frame:0
TX packets:218 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:11200653 (10.6 MiB) TX bytes:22484 (21.9 KiB)
Interrupt:27
-00
wwan0 Link encap:Ethernet HWaddr EE:D1:EB:32:D6:ED
root@NVTEVM:/mnt/app$ ls
lite-qmi-connection-managerarm64
lite-qmi-connection-managerarm64linaro
lite-qmi-connection-managerhosti686
lite-qmi-connection-managermipseb
lite-qmi-connection-managermipsel
lite-qmi-connection-managerrpi
root@NVTEVM:/mnt/app$ ./liroot@NVTEVM:/mnt/app$ ./lite-qmi-connection-managerhosroot@NVTEVM:/mnt/app$ ./lite-qmi-connection-managerhostxroot@NVTEVM:/mnt/app$ ./lite-qmi-connection-managerhostx86_64
./lite-qmi-connection-managerhostx86_64: line 1: syntax error: unexpected “)”
root@NVTEVM:/mnt/app$ root@NVTEVM:/mnt/app$ ./lite-qmi-connection-managerhostx86_64
root@NVTEVM:/mnt/app$ root@NVTEVM:/mnt/app$ ./lite-qmi-connection-managerhostx86_64 arroot@NVTEVM:/mnt/app$ ./lite-qmi-connection-managerarm
Interface id: 0x8
Model: RC7630
HomeNetwork: CMHK
1.start a single-PDN data session
2.Start one connection of a multi-PDN data session
3.Stop one connection
4.Stop all active connections
5.Display all profiles on the device
6.Display one profile on the device
7.Create a profile on the device
8.Modify an existing profile on the device
9.Delete a profile from the device
10.Scan available networks
11.Enable QOS Event
12.Disable QOS Event
13.Request QOS Expanded
14.Get QOS Information
15.QOS Indication Register
16.Read QOS Data Statistics (SWIQOS)
17.Read QOS Extra APN Parameters (SWIQOS)
18.Get Packet Statistics
19.Get Current Channel Rate
20.Toggle pinging on connection
21.Toggle routing table update on connection
22.Get loopback
23.Set loopback
24.Get data format
25.Set data format
26.Enable/disable WDS event report indication
27.Enable/disable keep data session alive
28.Get delegated IPv6 prefix
29.Remove delegated IPv6 prefix
(q)uit to exit:
login[557]: root login on ‘pts/1’
10
NetworkScan may take a few minutes. Result will be displayed when available. P
lease wait…
11.Enable QOS Event
22.Get loopback
23.Set loopback
24.Get data format
25.Set data format
(q)uit to exit:
unpack_nas_PerformNetworkScan ret: 0
Network Scan Result: 0
Network 0: LG U+
MCC/MNC: 450/6
In Use: Available(2)
Forbidden: Not forbidden(2)
Preferred: Not preferred(2)
Roaming: Roam(2)
RAT: LTE(8)
MNC includes PCS digit: FALSE
Network 1: 450 30
MCC/MNC: 450/30
root@NVTEVM:/home$
root@NVTEVM:/home$ ifconfig -a
Interrupt:27
-00
Interface id: 0x8
Interface id: 0x8
Model: RC7630
HomeNetwork: CMHK
22. Get loopback
23. Set loopback
24. Get data format
25. Set data format
(q)uit to exit:
2
cmhk disabled
Interrupt:27
-00
-00
-00
-00
-00
-00
ted…
<<<<<< RAW:
<<<<<< length = 16
<<<<<< QMUX:
<<<<<< length = 15
<<<<<< flags = 0x00
<<<<<< client = 0
<<<<<< QMI:
<<<<<< TLV:
<<<<<< length = 1
<<<<<< value = 02
<<<<<< RAW:
<<<<<< length = 24
:00:02:02
lated)…
<<<<<< QMUX:
<<<<<< length = 23
<<<<<< flags = 0x80
<<<<<< client = 0
<<<<<< QMI:
<<<<<< TLV:
<<<<<< length = 4
<<<<<< TLV:
<<<<<< length = 2
<<<<<< RAW:
<<<<<< length = 13
<<<<<< QMUX:
<<<<<< length = 12
<<<<<< flags = 0x00
<<<<<< client = 2
<<<<<< QMI:
<<<<<< RAW:
<<<<<< length = 47
lated)…
<<<<<< QMUX:
<<<<<< length = 46
<<<<<< flags = 0x80
<<<<<< client = 2
<<<<<< QMI:
<<<<<< TLV:
<<<<<< length = 4
<<<<<< TLV:
<<<<<< length = 1
<<<<<< value = 30
<<<<<< TLV:
<<<<<< length = 15
<<<<<< TLV:
<<<<<< length = 2
ESN: ‘0’
MEID: ‘unknown’
IMEI SV: ‘17’
s ‘release-cid’…
D ‘2’
<<<<<< RAW:
<<<<<< length = 17
<<<<<< QMUX:
<<<<<< length = 16
<<<<<< flags = 0x00
<<<<<< client = 0
<<<<<< QMI:
<<<<<< TLV:
<<<<<< length = 2
<<<<<< RAW:
<<<<<< length = 24
:00:02:02
lated)…
<<<<<< QMUX:
<<<<<< length = 23
<<<<<< flags = 0x80
<<<<<< client = 0
<<<<<< QMI:
<<<<<< TLV:
<<<<<< length = 4
<<<<<< TLV:
<<<<<< length = 2
for the log in connection manager, it is not complete, so not sure where the problem is.
Please note that you cannot quit the connection manager application after establishing data connection, otherwise the data channel will be dropped.
On the other hand, I don’t see there is any log by using AT!SCACT and qmi-network.
