Hi All,
I’m unable to create GSM port using the WP7607-1 module , as shown in the image below.
But I try in RC7620-1 module can create GSM port.And GSM can workable.
Could someone please help to solve this issue?Thanks
Hi All,
have you set
AT!MUXMODE=2
Is /dev/ttyUSB1 the AT command port?
Hi @jyijyi ,
Thanks for your reply.
AT!MUXMODE=2 is Enable CMUX over USB. I’m now trying CMUX over UART, and I’ve also tried using USB, but the same fails.
Yes,ttyUSB1 is the AT port.
I never tried with UART, I remember i used the following on USB:
on module, need to type AT!MUXMODE=2 and reset the module, so that mux mode is enabled in USB.
sudo ./gsmMuxd -c -f 31 -d -p /dev/ttyUSB2 -b 115200 -s /dev/mux -w -m wavecom /dev/ptmx /dev/ptmx
gsmmux.rar (80.7 KB)
