Hi all. I have problem with WP 7607-2 Seri. When I enable ADB port (“AT!USBCOMP=1,1,10F”) to use with SSH connection via MobaXTerm, after open ADB port successfully I can’t access to UART port. I can’t send AT command to it. When I trying to open UART port, it returned “Invalid argument comport”. But when I disable ADB port, it works correctly, I can send AT command and open UART comport. Help me please, thanks.
My firmware is: Legato Ver: 19.04.0_6fbb8d1e27e320ebcd2971fdae7df87f
Yocto Ver: SWI9X07Y_02.31.01.00 2019-06-14
Seems the ADB port is not supposed to be used.
at!usbcomp=?
!USBCOMP:
AT!USBCOMP=,,
- configuration index to which the composition applies, should be 1
- 1:Generic
- DIAG - 0x00000001,
NMEA - 0x00000004,
MODEM - 0x00000008,
RAWDAT - 0x00000040,
RMNET0 - 0x00000100,
RMNET1 - 0x00000400,
RMNET2 - 0x00000800,
AUDIO - 0x00010000,
ECM - 0x00080000,
NCM - 0x00400000,
e.g.
9 - diag,modem interfaces enabled
10D - diag,nmea,modem,rmnet0 interfaces enabled
ati3
Model: WP7608
Revision: SWI9X07Y_02.28.03.03 000000 jenkins 2019/05/21 03:33:04
IMEI: 352913090100734
IMEI SV: 6
FSN: XG805285330204
+GCAP: +CGSM
ati8
Legato Ver: 19.02.0_4cb954265427b8c2c668a010ff5be274_modified
Yocto Ver: SWI9X07Y_02.28.03.03 2019-05-21_07:00:11
OS Ver: Linux version 3.18.131 (oe-user@oe-host) (gcc version 7.3.0 (GCC) ) #1 PREEMPT Tue May 21 06:09:42 UTC 2019
LK Ver: SWI9X07Y_02.28.03.03
RootFS Ver: SWI9X07Y_02.28.03.03 2019-05-21_07:00:11
UserFS Ver: unknown
MCU Ver: 002.011
Thank Jyijyi so much! Bellow is my logfile
"at!usbcomp?
Config Index: 1
Config Type: 1 (Generic)
Interface bitmask: 0008010D (diag,nmea,modem,rmnet0,ecm)
at!usbcomp=?
!USBCOMP:
AT!USBCOMP=,,
- 1:Generic
ADB - 0x00000002,
NMEA - 0x00000004,
MODEM - 0x00000008,
AUDIO - 0x00010000,
ECM - 0x00080000,
NCM - 0x00400000,
e.g.
B - diag,adb,modem interfaces enabled
10F - diag,adb,nmea,modem,rmnet0 interfaces enabled
OK"
It’s my logfile when I check usbcomp. My problem is UART port not work when ADB port open. If I set value of usbcomp to “0008010F”, then adb port will open and I can’t send AT command to module WP via UART port. If I set value of usbcomp to “0008010D”, then adb port will closed and disable and I can send AT command to module. ADB port and UART port can’t not working correctly at the same time. I trying upgrade and downgrade to new and old firmware version but problem not fix.
not sure why I cannot see ADB port with WP7607-1:
at!usbcomp=?
!USBCOMP:
AT!USBCOMP=,,
- 1:Generic
NMEA - 0x00000004,
MODEM - 0x00000008,
AUDIO - 0x00010000,
ECM - 0x00080000,
NCM - 0x00400000,
e.g.
ati3
Model: WP7607-1
IMEI: 359780080500170
IMEI SV: 6
FSN: V2842570321010
+GCAP: +CGSM
ati8
UserFS Ver: unknown
MCU Ver: 002.011
Did you level 3 unlock the module? ADB port is not supposed be used by user.
Model: WP7608
IMEI SV: 6
FSN: XG805285330204
+GCAP: +CGSM
at!entercnd=“A710”
at!usbcomp=?
!USBCOMP:
AT!USBCOMP=,,
- 1:Generic
NMEA - 0x00000004,
MODEM - 0x00000008,
AUDIO - 0x00010000,
ECM - 0x00080000,
NCM - 0x00400000,
e.g.
at!unlock=“A710”
at!usbcomp=?
!USBCOMP:
AT!USBCOMP=,,
- 1:Generic
ADB - 0x00000002,
NMEA - 0x00000004,
MODEM - 0x00000008,
AUDIO - 0x00010000,
ECM - 0x00080000,
NCM - 0x00400000,
e.g.
BTW, how can you level 3 unlock the module?
I used AT!UNLOCK=“A710”
I can still enter AT command in the UART console:
root@swi-mdm9x28-wp:~# microcom /dev/ttyAT
ati3
Model: WP7608
IMEI SV: 6
FSN: XG805285330204
+GCAP: +CGSM
at!entercnd=“A710”
at!usbcomp?
Config Index: 1
Interface bitmask: 0008010F (diag,adb,nmea,modem,rmnet0,ecm)
Yes! I can do the same as you. But I want to enter AT command in the UART console with AutoPilot , not use microcom -X /dev/ttyAT. Because I have to run automations test case.
I don’t see problem in UART1 as AT command port:
ati3
Model: WP7608
IMEI SV: 6
FSN: XG805285330204
+GCAP: +CGSM
at!entercnd=“A710”
aT!mapuart?
!MAPUART: 1,16
at!usbcomp?
Config Index: 1
