I’m new at OpenAT and I’m playing with some of the plugin samples to get an understanding of how they work. I loaded the WIPSoft plugin sample but I’m having the following problem when building it:
Hi eddie435,
You should remove all the Wavecom SDK and re-install. It is sometimes get the problem at the installation. (You are using Q2686 or Q2687 for Fastrack Supreme 10 or 20)
ttt
Generally, you can’t call custom AT commands from an Open-AT application using adl_ATCmdCreate.
Also, as I understand it, WIPsoft is itself an Open-AT application; you can only have one Open-AT application loaded at a time - so you can’t have both WIPsoft and your own Open-AT application loaded simultaneously.
So, if you want to use WIP with your Open-AT Application, then use the WIP plugin instead…
In the Sample WIPSoft application, it says that I can use +WIP AT commands after the wip_atcmdsubscribe is executed. My question is how do I access the +WIP AT commands in my code? The example doesn’t show nor does the documentation (that I could find). Please, if you know what I need in my code to run for example the “AT+WIPCFG=1” command, please let me know. thanks.
