I have look into the AT command sheet but couldn’t see the WIPCREATE command to support username & password option like:
AT+WIPCREATE = 5,1,“servername.com”,“username”,“password”,"";
Is this option only available on other modules?
Thank you.
Thank you.
Username and password option is available with mode 4(FTP),5(HTTP Client),6(SMTP Client),7(POP3 Client).
Refer to the WIP AT command guide.
And,what is meant by “this option only available on other modules”?
Thanks.
If you look at the AT command datasheet for WISMO228, the option can only be 1,2 or 3.
I think this is probably because it doesn’t have other stack than TCP & UDP embedded.
