Hi, has anyone here experienced modem hanging sometimes when using WIP AT commands? I’m experiencing this very often and this makes a real-life application impossible. When it hangs, the modem signal light still flashes, but there’s no way to communicate with the modem via serial port.
Specifically, after issuing a WIP command, i get the following response and it hangs from there. I am at my wit’s ends, hope someone can help. thks.
œœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœœ
I’m not exactly sure, but last week I found out that the modem can also hang with a simple AT+CMGL=4. Although less common.
By the way, I’m using the USB GL6110 under Windows 2008 Server, could the issue be the USB driver? Will changing the baud rate help?
I like to add that disabling and enabling the modem via Windows device manager won’t resolve the issue. In the meantime, the modem light is still blinking.
