There’s no reply since, but I’m still facing this issue. I’ve managed to minimize the chance of it happening by spacing out the AT commands so that I would not issue a new command before the previous one returns a response.
Now I’m wondering if WIPsoft can be made to use a watchdog to reset the module if it hangs? Thanks.
Hi Ijweko, thanks for your quick response. I took a look at AT+WRST. This probably won’t work if WIPsoft or the module hangs because no AT command can be sent to the terminal when that happens.
Well, you have to issue AT+WRST command first, with timeout sufficient to execute intended WIP process. After success, disable WRST again. In case of failure, auto reset should fire.
Hi ljweko, after some experiments, I confirm that this really works. It acts as a watchdog and issuing AT+WRST=1,“000:nn” again will reset the watchdog. It’s a wonder that this useful feature isn’t prominently highlighted or discussed.
