We recently purchased some new RV50 modems. I was able to manually set them up using ipaddress:9191 to talk over the web. Is there a setting that I may have missed or is it just some of these modems will not talk and I should be happy to talk to one?
Hi Jayaldrich,
Couple of things, either a setting or the ip address is not a routable ip. You’ll need to check with your carrier if the ip’s are routable on the internet.
The setting to allow remote connection:
Services->ACEManager->Remote access->select either HTTPS only or both HTTP & HTTPS from the drop down menu.
Click apply and reboot device.
If this is set to disabled, you wont be able to access the unit’s ACEManager remotely.
Hope that clarifies.
Thanks kindly,
Jay.
