i don’t see there is EM7455 module connected to your PC…
the cellular connection is on were do i go to
I’m lost what do i do now, please
I don’t see there is modem port enumerated in your module, try this:
- download the GenericDriverSetup_5087.exe from SOURCE website
- open a folder and put GenericDriverSetup_5087.exe and Configuration.ini together
- open Configuration.ini and add the following:
[Default Values]
CHECKFORDEVICE=0
LOCATIONDRIVER=1
WIN8LOCATION=1
USBCOMP=99
- now install the driver again
Or you can see more information here:
Can you kindly link the website for both the GenericDriverSetup_5087.exe and the Configuration.ini
Or were do i find configuration.ini
you can do search in SOURCE website
https://source.sierrawireless.com/resources/#sthash.RHudM9xe.dpbs=&tags=GenericDriverSetup
Configuration.ini (84 Bytes)
I’m done and now the port’s aren’t showing and My pc stopped charging as well
what is the relationship between the battery charging and the modem?
I saw there is modem port in your device manager
the modem icon disappeared
you can open Configuration.ini and change “USBCOMP=8” and run the driver setup again
you can then send AT command through modem port in device manager
so if i wanted to do *124# what would i type in (or is there a manual on how to do at commands)
