Using a RV50x to connect to a Sharepoint URL instead of IP address
Just to get some facts out there. I am not an expert at all the settings that are possible with the RV50x but i believe i can fumble through most. I am currently using Aleos version 4.15.3. Before I upgrade i would like to know if the router has capabilities to create link to a Microsoft Sharepoint URL instead of an IP address. Either with the current version or if I upgrade to the highest version possible. If its possible. Can someone please provide some information on how to do so. Currently I have it setup and working properly to send data to a AWS but do not want to continue using this option.
Thank you
Hi @joseph.fuhrman,
Welcome to our community!
Based on your description, I understand that you currently have the router set up to send data to a AWS, but now you would like to send data to a Microsoft SharePoint URL instead. Is that correct?
If not, could you please clarify your question so I can support you better?
