i have gsm modem wavecom M1306B, because my computer havent serial port, i use Bafo BF810(USB To Serial Adapter). i have configure bits per second=8 115.200 bps, data bits=8,parity=none, flow control=hardware in Prolific USB to Serial Comm port(BF810 Driver). when i try to connect in hyper terminal, nothing character is displayed (i have configure the correct port, bits per second=8 115.200 bps, data bits=8,parity=none, flow control=hardware)in hyper terminal properties). in modem led on permanent.
To have the text displayed on the Hyperterminal, please do these steps:
- Open the Hyperterminal (for the connection to GSM Modem)
- Go to Menu “File -> Properties”
- Click Tab “Settings”
- Press “ASCII Setup” Button.
- Check All the checkbox.
- Exit the settings now.
The text you type must be able to be seen by now…
Hope this helps…
