connected via ssh to the remote linux host
used a perl script with Modem and XModem modules that downloads a given dwl to the modem.
the perl script performs
AT+WDWL
send file via xmodem
AT+CFUN=1
I uploaded the following files:
R7.47.0_fsu004.dwl
dwl.dwl
Now I downloaded all the files you suggested in the correct sequence, but the led still not blinks.
The modem answers to at commands such ati9 but not tries to register to the network.
I tried the sim on another fastrack and it works.
Should I use a windows tool for try to reset completely the fastrack?
What is ATI3 reports and what is the model of your Fastrack.
While Fastrack will accept firmware destined for different unit (you can load FXT009 version into FXT003 for example), symptoms will be exactly as you describe – no registration, but AT interface works.
Firmware you are loading must match the unit hardware!
