Hi guys,
I got an EM9565-9 module for Lenovo laptop and would like to flash it to generic firmware to use on a WWAN box & a router. Unfortunately, I couldn’t flash the firmware. Can you guys help me out on this, please?
Here are things I’ve done:
The current firmware is 00.06.05.00 - GENERIC_001.007.000
I’ve tried to set up things on Ubuntu, flash the firmware to SWI9X50C_01.05.01.00_00_GENERIC_001.028_000, follow this guide on Github.
There was a successful message on the screen but it seems the new firmware never arrive.
I tried to flash again, three, four, five times - unfortunately, the result is the same
I ran AT!IMAGE=0, AT!RESET - then try to flash the firmware again, but no luck
I’ve tried to use AT!OPENLOCK command to unlock the module and flash it, but still the same
Here are several details from AT commands:
AT!PCINFO?
State: Low Power Mode
LPM voters - Temp:0, Volt:0, User:1, W_DISABLE:0, IMSWITCH:0, BIOS:1, LWM2M:0, OMADM:0, FOTA:0, RFCAL:0
LPM persistence - User:1OK
AT!GSTATUS?
!GSTATUS:
Current Time: 1248 Temperature: 30
Reset Counter: 11 Mode: LOW POWER MODEOK
AT!IMPREF?
!IMPREF:
preferred fw version: 00.06.05.00
preferred config name: GENERIC_001.007_000
current fw version: 00.06.05.00
current carrier name: GENERIC
current config name: GENERIC_001.007_000OK
AT!PRIID?
PRI Part Number: 9907220
Revision: 001.004
Customer: Lenovo-LaptopCarrier PRI: 9999999_9907259_SWI9X50C_01.05.01.00_00_GENERIC_001.028_000
AT!IMAGE?
FW 1 EMPTY 0 0 0
FW 2 EMPTY 0 0 0
FW 3 EMPTY 0 0 0
FW 4 EMPTY 0 0 0
Max FW images: 4
Active FW image is at slot 255TYPE SLOT STATUS LRU FAILURES UNIQUE_ID BUILD_ID
PRI FF GOOD 0 0 0 001.028_000 01.05.01.00_GENERIC
Max PRI images: 50OK
AT!USBCOMP?
Config Index: 1
Config Type: 3 (Generic)
Interface bitmask: 0000100D (diag,nmea,modem,mbim)
I’ve tried to set AT+CFUN=1 to get out of LPM, but it doesn’t work.
+CME ERROR: operation not supported
It seems this module is tied with Lenovo machine & its BIOS.
Can you guys please help me to make it work? Here is the firmware upgrade log: firmware-update-log - JustPaste.it
