Hi, got this guy and got LPM, any help?
AT!IMPREF?
!IMPREF:
preferred fw version: 02.38.00.00
preferred config name: GENERIC_002.082_000
preferred subpri index: 000
current fw version: 02.38.00.00
current carrier name:
current config name:
current subpri index: 000
carrier name mismatch
config name mismatch
AT!ENTERCND=“A710”
ERROR
AT!GSTATUS?
!GSTATUS:
Current Time: 303 Temperature: 36
Reset Counter: 13 Mode: LOW POWER MODE
jyijyi
2
you might need to redownload the FW+PRI
ok, mb you can correct my steps.
- Setup GenericDriverSetup_5087.exe
- “AT!IMAGE=0”, “AT!RESET”
Summary
C:\Users\Lenovo\Desktop\firm>@bin\atscr COM%PORT% AT!IMAGE=0
AT!IMAGE=0
C:\Users\Lenovo\Desktop\firm>@bin\atscr COM%PORT% “at!image?”
at!image?
FW 1 EMPTY 0 0 0
FW 2 EMPTY 0 0 0
FW 3 EMPTY 0 0 0
FW 4 EMPTY 0 0 0
Max FW images: 4
Active FW image is at slot 255
Max PRI images: 50
- fdt2.exe -d g5k -ignswto -force
Summary
C:\Users\Lenovo\Desktop\firm>fdt2.exe -d g5k -ignswto -force
FDT version: 2.0.2012.0
Awaiting adapter …
Setting images preference …
Disabling selective suspend …
Resetting …
Awaiting download port …
Downloading images …
Writing image -
Flashing image |
Writing image /
Flashing image -
Enabling selective suspend …
Awaiting adapter …
Checking update status …
Firmware image download succeeded.
Final Firmware update succeeded.
Current:
Firmware:
ImageId:
BuildId: 02.38.00.00_
Configuration:
ImageId:
Final images information:
Current:
Firmware:
ImageId:
Configuration:
ImageId:
OEM PRI: 9907220 001.004 Generic
IMEI:XXXXXXXXXXXXXXXXXXXXXXX
Total time elapsed: 132969 ms.
Time to switch to boot mode: 16532 ms.
Images downloaded:
Image ID: ??
Build ID: 02.38.00.00?
write time: 4937 ms
additional flash time: 55157 ms
Image ID: 002.082_000
Build ID: 02.38.00.00_GENERIC
write time: 15 ms
additional flash time: 78 ms
Time to reset to application mode: 55047 ms.
Press Enter to continue …
- @bin\atscr COM%PORT% “at!image?”
Summary
at!image?
FW 1 GOOD 1 0 0 ?? 02.38.00.00?
FW 2 EMPTY 0 0 0
FW 3 EMPTY 0 0 0
FW 4 EMPTY 0 0 0
Max FW images: 4
Active FW image is at slot 1
PRI FF GOOD 0 0 0 002.082_000 02.38.00.00_GENERIC
Max PRI images: 50
jyijyi
4
