I accidentally flashed a new firmware onto the Modem and now i can’t get it out of low power mode or flash to another firmware.
AT!IMPREF?
!IMPREF:
preferred fw version: 02.24.05.06
preferred config name: GENERIC_002.026_000
preferred subpri index: 000
current fw version: 02.33.03.00
current carrier name: GENERIC
current config name: GENERIC_002.026_000
current subpri index: 000
fw version mismatch
This is the version mismatch i have, but everytime i try to flash another firmware onto it, i get
FDT version: 1.0.1806.0
Awaiting adapter ...
Enabling selective suspend ...
Firmware download failed.
Primary error code: 82 - Failed in checking modem mode.
Secondary error code: 0 - Not applicable.
Device error code: 0x0 - Unknown device error code.
Current:
Firmware:
ImageId:
BuildId:
Configuration:
ImageId:
BuildId:
Final images information:
Current:
Firmware:
ImageId:
BuildId:
Configuration:
ImageId:
BuildId:
OEM PRI:
IMEI:
Total time elapsed: 172 ms.
Images downloaded:
Press Enter to continue ...
i need a link for the old firmware (since i only have newer one) and a way to flash it to the modem, but i simply don’t know how to do anymore.
if you can help me i will be very grateful, thank you.
jyijyi
September 18, 2024, 3:13pm
2
Thank you for the Firmware link!
Yes, i installed both Qualcomm-HS-USB-QDLoader-9008-Driver and Qualcomm USB Driver v1.0.10061.1.
I still get
FDT version: 1.0.1702.1
Current:
Firmware:
ImageId:
BuildId:
Configuration:
ImageId:
BuildId:
Current:
Firmware:
ImageId:
BuildId:
Configuration:
ImageId:
BuildId:
OEM PRI:
IMEI:
Total time elapsed: 125 ms.
Images downloaded:
when trying to run FDT.
While using QFIL, it says no port available
which i guess is because the modem doesn’t show up as a COM Port, but as a Network Adapter
My guess is that this whole trouble is over once i flash the old correct firmware, but i dont know how to that with all the errors i am encoutering.
jyijyi
September 19, 2024, 7:32am
4
Yes, i have this driver installed and i used the FW Upgrade exe tool (9999999_9904609_SWI9X30C_02.24.05.06_00_GENERIC_002.026_000.exe).
When executing it, i get
Current:
Firmware:
ImageId:
BuildId:
Configuration:
ImageId:
BuildId:
Current:
Firmware:
ImageId:
BuildId:
Configuration:
ImageId:
BuildId:
OEM PRI:
IMEI:
Images downloaded:
Press Enter to continue ...```
jyijyi
September 19, 2024, 8:19am
6
how about other exe like upgrading to SWI9X30C_02.38.00.00?
Always the same, no matter with one i used.
jyijyi
September 19, 2024, 8:37am
8
what is the response of the following?
ati3
at!impref?
at!entercnd="A710"
at!usbcomp?
at!usbcomp=?
BTW, you can see here on other user update the DELL DW5819 driver: (From your screenshot, you are using DW5818)
i installed the driver and now it shows up as a COM-Port
but the exe is still not working properly. Should i use QFIL?
here are the responses.
ati3
Model: MC7455B
Revision: SWI9X30C_02.33.03.00 r8209 CARMD-EV-FRMWR2 2019/08/28 20:59:30
MEID: 35907206696228
IMEI: 359072066962289
IMEI SV: 20
FSN: LQ835688730410
+GCAP: +CGSM
at!impref?
!IMPREF:
fw version mismatch
AT!entercnd="A710"
AT!usbcomp?
Config Index: 1
Config Type: 1 (Generic)
Interface bitmask: 0000100D (diag,nmea,modem,mbim)
AT!usbcomp=?
!USBCOMP:
AT!USBCOMP=<Config Index>,<Config Type>,<Interface bitmask>
<Config Index> - configuration index to which the composition applies, should be 1
<Config Type> - 1:Generic, 2:USBIF-MBIM, 3:RNDIS
config type 2/3 should only be used for specific Sierra PIDs: 68B1, 9068
customized VID/PID should use config type 1
<Interface bitmask> - DIAG - 0x00000001,
NMEA - 0x00000004,
MODEM - 0x00000008,
RMNET0 - 0x00000100,
RMNET1 - 0x00000400,
MBIM - 0x00001000,
e.g.
10D - diag, nmea, modem, rmnet interfaces enabled
1009 - diag, modem, mbim interfaces enabled
The default configuration is:
at!usbcomp=1,1,10F
jyijyi
September 19, 2024, 9:10am
10
how about using RMNET in AT!USBCOMP?
AT!ENTERCND="A710"
AT!USBCOMP=1,1,10d
AT!RESET
i now have 3 COM Ports, but either 2 of them are active, or the other one
my AT Commands only work on COM6.
This is another thing that is happening. When i connect it, i have a small time windows in which com5&com6 are there and then it disconnects and only com3 is there.
on my linux VW, it behaves likes this:
i have ttyUSB0, ttyUSB1 and ttyUSB2 at first and i can type my commands with screen/dev/ttyUSB2/.
but then, it kicks me and only ttyUSB0 is there. when i open screen/ttyUSB0/, every character i enter is displayed as ‘0’, with now way to press enter (pressing enter will just add another ‘0’).
AT Commands work for a brieve moment on COM6/ttyUSB2
after that, only COM3/ttyUSB0 is available with only zeroes
i did enter your AT Commands.
AT
AT!ENTERCND="A710"
AT!USBCOMP=1,1,10D
AT!RESET
jyijyi
September 19, 2024, 11:43am
12
if you use AT!USBCOMP=1,1,100D as previous case, will the module kick you out from AT command mode?
