EM7455 fail to upgrade firmware
FDT version: 2.0.2012.0
Awaiting suitable port or adapter …
Switching to boot & hold mode …
Disabling selective suspend …
Awaiting download port …
Downloading images …
Writing image -
Flashing image
Enabling selective suspend …
Awaiting adapter …
Checking update status …
Firmware download failed.
Primary error code: 67 - Firmware update process timeout.
Secondary error code: 0 - Not applicable.
Device error code: 0x0 - Unknown device error code.
Current:
Firmware:
ImageId: 002.072_000
BuildId: 02.33.03.00_GENERIC
Configuration:
Final images information:
Current:
Firmware:
ImageId:
BuildId:
Configuration:
ImageId:
BuildId:
OEM PRI:
IMEI:
Total time elapsed: 480141 ms.
Time to switch to boot mode: 18609 ms.
Images downloaded:
Image ID: ??
Build ID: 02.38.00.00
write time: 5031 ms
additional flash time: 109 ms
Time to reset to application mode: 166813 ms.
Press Enter to continue …
Hi to all. I can’t manage to upgrade to the latest firmware on this module. I have fdt2 , cwe , nvu in the same folder and i get the above. Also if i change sim i need to wait for a long time and with many restarts to be recognized. My laptop is a Lenovo T470s on Windows 10 x64. Do you have any solution?
have you tried the EXE for upgrading FW?
https://source.sierrawireless.com/resources/airprime/minicard/74xx/em_mc74xx-approved-fw-packages/#sthash.iakDkt98.dpbs
Yes, the upgrade process made with the .exe
what is the current FW (i.e. ati3) in your module now?
The current is 2.33.03
how about using fdt after “AT!BOOTHOLD”?
e.g.
fdt2.exe -f xxx.cwe xxx.nvu
I will try this later and post results here
