Hi All,
I recently received a mangOH Red, and installed a WP7603-1 module into it.
I have been unable to ping or get any sort of response from the module while trying to build/update it.
However, I did swap power over to the console, and saw the following read out during boot.
Do these have different IP’s than the WPx5xx series? Or is there something else going on here?
I appreciate the help.
[code]Welcome to minicom 2.7
OPTIONS: I18n
Compiled on Feb 7 2016, 13:37:27.
Port /dev/ttyUSB0, 08:00:52
Press CTRL-A Z for help on special keys
[930] DEBUG: cmdline has root=
[1070] Channel alloc freed
[ 0.000000] GIC CPU mask not found - kernel will fail to boot.
[ 0.000000] MPM 1 irq mapping errored -517
[ 0.071968] sierra:-sierra_smem_get_factory_mode-failed: smem have not initid
[ 0.213723] spmi_pmic_arb 200f000.qcom,spmi: PMIC Arb Version-2 0x20010000
[ 0.227472] msm_mpm_dev_probe(): Cannot get clk resource for XO: -517
[ 0.230395] smd_channel_probe_now: allocation table not initialized
[ 0.237533] msm_thermal:msm_thermal_dev_probe Failed reading node=/soc/qcom,7
[ 0.263752] msm_mpm_dev_probe(): Cannot get clk resource for XO: -517
[ 0.266473] msm_thermal:get_kernel_cluster_info CPU0 topology not initialize.
[ 0.267383] cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19)
[ 0.267401] msm_thermal:get_cpu_freq_plan_len Error reading CPU0 freq table 9
[ 0.268112] cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19)
[ 0.268127] msm_thermal:get_cpu_freq_plan_len Error reading CPU0 freq table 9
[ 0.268142] cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19)
[ 0.268154] msm_thermal:get_cpu_freq_plan_len Error reading CPU0 freq table 9
[ 0.359437] AXI: msm_bus_scale_register_client(): msm_bus_scale_register_cli.
[ 0.362016] AXI: msm_bus_scale_register_client(): msm_bus_scale_register_cli0
[ 0.412791] msm_bus_fabric_init_driver
[ 0.600305] SWI ssmem_framework_init: SSMEM init OK
[ 0.620963] scm_call failed with error code -4
[ 0.620982] msm_audio_protect_memory_region: SCM call failed, scm_call_ret -0
[ 0.625621] uart_tx_gpio is not available
[ 0.625640] uart_rx_gpio is not available
[ 0.625659] uart_cts_gpio is not available
[ 0.625677] uart_rfr_gpio is not available
[ 0.626319] sps: BAM device 0x07884000 is not registered yet.
[ 0.631535] AXI: get_pdata(): Error: Client name not found
[ 0.631545] AXI: msm_bus_cl_get_pdata(): client has to provide missing entryn
[ 0.631553] msm_serial_hsl_probe: Bus scaling is disabled
[ 0.841812] mdm9607-pinctrl 1000000.pinctrl: pin GPIO_4 already requested byl
[ 0.852301] mdm9607-pinctrl 1000000.pinctrl: pin-4 (78b0000.serial) status -2
[ 0.859444] mdm9607-pinctrl 1000000.pinctrl: could not request pin 4 (GPIO_4l
[ 0.870417] msm_serial_hsl 78b0000.serial: Error applying setting, reverse tk
[ 0.926675] sps: BAM device 0x07984000 is not registered yet.
[ 1.011280] unable to find DT imem DLOAD mode node
[ 1.015332] unable to find DT imem EDLOAD mode node
[ 1.020293] unable to find DT imem dload-type node
[ 1.024839] Failed to disable secure wdog debug: -4
[ 1.055910] devfreq soc:qcom,cpubw: Couldn’t update frequency transition inf.
[ 1.063917] sdhci_msm 7864900.sdhci: sdhci_msm_pm_qos_parse_irq: error -22 ru
[ 1.071928] i2c-msm-v2 78b8000.i2c: msm_bus_scale_register_client(mstr-id:86)
[ 1.153575] bmi160 4-0068: BMI160 qpio number:78
[ 1.169178] mdm9607-pinctrl 1000000.pinctrl: pin GPIO_79 already requested bc
[ 1.215146] mdm9607-pinctrl 1000000.pinctrl: pin-79 (soc:qcom,msm-dai-mi2s:q2
[ 1.239769] mdm9607-pinctrl 1000000.pinctrl: could not request pin 79 (GPIO_l
[ 1.267317] msm-dai-q6-mi2s soc:qcom,msm-dai-mi2s:qcom,msm-dai-q6-mi2s-sec: k
[ 1.316976] mdm9607-asoc-snd soc:sound-wm8944: Defering mdm_asoc_machine_pro0
[ 1.365267] mdm9607-asoc-snd soc:sound-wm8944: Defering mdm_asoc_machine_pro0
[ 1.408652] mdm9607-asoc-snd soc:sound-wm8944: Defering mdm_asoc_machine_pro0
[ 1.442210] mdm9607-asoc-snd soc:sound-wm8944: Defering mdm_asoc_machine_pro0
[ 1.451025] calculate_residency: residency < 0 for LPM
[ 1.455126] parse_cpu_levels: idx 1 420
[ 1.458943] calculate_residency: residency < 0 for LPM
[ 1.503918] parse_cpu_levels: idx 2 500
[ 1.506723] parse_cpu_levels: idx 2 3040
[ 1.532713] mdm9607-asoc-snd soc:sound-wm8944: Defering mdm_asoc_machine_pro0
[ 1.552015] mdm9607-asoc-snd soc:sound-wm8944: Defering mdm_asoc_machine_pro)
Non-secure.
UBI device number 0, total 120 LEBs (30474240 bytes, 29.1 MiB), available 5 LEB)
[ 7.094052] device-mapper: table: 253:0: verity: Cannot initialize hash funcn
device-mapper: reload ioctl failed: No such file or directory
Device: rt ubiImgBlock:/dev/ubiblock0_0 hashBlock:/dev/ubiblock0_1
root_hash:40636ee2e72095cf3974f93617bb07dc12cf9038a4a713b1261c7094c341114e
Dm-verity partition creation failed.
rootfs: dev ‘/dev/ubiblock0_0’ ‘squashfs’
rootfs: mounting took 10ms
init started: BusyBox v1.22.1 (2017-07-01 02:04:23 UTC)
rcS: Executing mount_essential_fs…
rcS: Executing simple_network…
rcS: Executing run_S_scripts…
S02mount_early: Executing mount_early_pseudo…
S02mount_early: Executing mount_early_other…
S02mount_early: Executing mount_early_create_dirs…
S02mount_early: Executing mount_early_user_start…
S02mount_early: User is forcing userapp file system to be ubifs.
S02mount_early: Trying to mount UBIFS on /mnt/flash using [usrquota,grpquota,rw.
S02mount_early: UBI: mtd 16 is UBI.
UBI device number 3, total 524 LEBs (133070848 bytes, 126.9 MiB), available 5 L)
S02mount_early: Performing quota check on file system mounted at /mnt/flash
S02mount_early: UBIFS volume successfully mounted on /mnt/flash
S02mount_early: Executing mount_early_legato_start…
Can’t get valid SMEM, init DSSD SMEM
Linux sub system 1
mount Legato from partition lefwkro
UBI device number 2, total 35 LEBs (8888320 bytes, 8.5 MiB), available 0 LEBs ()
S02mount_early: Non-secure !
S02mount_early: UBI: mtd 14 is UBI.
S02mount_early: SQUASHFS successfully mounted on /mnt/legato
S02mount_early: Executing mount_early_userrw_start…
S02mount_early: Mounting swirw file system as UBIFS
S02mount_early: Trying to mount UBIFS on /mnt/userrw using [usrquota,grpquota,r.
S02mount_early: UBI: mtd 15 is UBI.
UBI device number 4, total 100 LEBs (25395200 bytes, 24.2 MiB), available 2 LEB)
S02mount_early: Performing quota check on file system mounted at /mnt/userrw
S02mount_early: UBIFS volume successfully mounted on /mnt/userrw
S02mount_early: swirw mounted to /mnt/userrw
S03confighw.sh: Kernel internal entropy pool filler is available, increasing wr2
S04mount_unionfs: RO rootfs fudge allowed.
Mounting local filesystems…
[ 15.199009] UBIFS error (pid: 433): cannot open “ubi0:usrfs”, error -19mounte
MTD : Detected block device : /firmware for modem
UBI device number 1, total 128 LEBs (32505856 bytes, 31.0 MiB), available 0 LEB)
Initializing random number generator…
Switching to composition sierra_dev (1199:68C0)
[ 16.033396] enable_store: android_usb: already disabled
Configuring network interfaces… done.
Starting syslogd/klogd: done
ifconfig: SIOCGIFFLAGS: No such device
Starting diagrebootapp: done
$Starting qcom_time:
starting time-daemon
Starting time_services: done
Legato start sequence
restart_at_uart: Mapped UART1 for AT service
Finished Legato start Sequence
Starting reboot daemon: done
Starting atreset: done
Starting modem dependent daemons: [ 26.820989] M-Notify: General: 7
[ 26.863612] msm-pcm-routing soc:qcom,msm-pcm-routing: ASoC: Failed to add ror
[ 26.896865] msm-pcm-routing soc:qcom,msm-pcm-routing: ASoC: Failed to add ror
[ 26.927077] msm-pcm-routing soc:qcom,msm-pcm-routing: ASoC: Failed to add ror
[ 27.008516] msm-pcm-routing soc:qcom,msm-pcm-routing: ASoC: Failed to add ror
[ 27.023877] diag: In diag_send_feature_mask_update, control channel is not oc
[ 27.185745] msm-pcm-routing soc:qcom,msm-pcm-routing: ASoC: Failed to add ror
[ 27.238051] msm-pcm-routing soc:qcom,msm-pcm-routing: ASoC: no source widgetX
[ 27.286511] msm-pcm-routing soc:qcom,msm-pcm-routing: ASoC: Failed to add ro3
[ 27.332965] msm-pcm-routing soc:qcom,msm-pcm-routing: ASoC: Failed to add ror
[ 27.367045] msm-pcm-routing soc:qcom,msm-pcm-routing: ASoC: Failed to add ror
[ 27.402773] msm-pcm-routing soc:qcom,msm-pcm-routing: ASoC: no sink widget fX
[ 27.427716] msm-pcm-routing soc:qcom,msm-pcm-routing: ASoC: Failed to add roX
Load modem done
Starting qmuxd: done
Starting thermal-engine: done
Starting irsc_util: Starting irsc tool
Failed to open file:/etc/sec_config
Absent/Invalid config,Default rules apply
Ending irsc tool
done
Starting netmgrd: done
Starting powerconfig for mdm9607: Starting fs-scrub-daemon: done
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.all.rp_filter = 1
[ 28.539606] msm-pcm-routing soc:qcom,msm-pcm-routing: ASoC: mux SLIM_0_RX AAs
rm: can’t remove ‘/var/log/wtmp’: No such file or directory
Starting qmi_ip: done
[ 28.728441] msm-dai-stub-dev soc:qcom,msm-dai-stub:qcom,msm-dai-stub-dtmf-txX
[ 28.785525] i2c-msm-v2 78b8000.i2c: NACK: slave not responding, ensure its p0
[ 28.925492] msm-dai-stub-dev soc:qcom,msm-dai-stub:qcom,msm-dai-stub-dtmf-txX
starting DNS forwarder and DHCP server: dnsmasq… [ 29.056932] msm-dai-stub-X
[ 29.122426] msm-dai-stub-dev soc:qcom,msm-dai-stub:qcom,msm-dai-stub-host-rxX
[ 29.189188] msm-dai-stub-dev soc:qcom,msm-dai-stub:qcom,msm-dai-stub-host-rxX
done.
[ 29.256558] msm-dai-stub-dev soc:qcom,msm-dai-stub:qcom,msm-dai-stub-host-rxK
Starting Dropbear SSH server: [ 29.330458] msm-dai-stub-dev soc:qcom,msm-dai-X
DONE
[ 29.385035] msm-dai-stub-dev soc:qcom,msm-dai-stub:qcom,msm-dai-stub-host-txX
[ 29.442684] msm-dai-stub-dev soc:qcom,msm-dai-stub:qcom,msm-dai-stub-host-txX
dropbear.
stopping DNS forwarder and DHCP server: dnsmasq… [ 29.510583] msm-dai-stub-K
stopped /usr/bin/dnsmasq (pid 968)
done.
starting DNS forwarder and DHCP server: dnsmasq… done.
run_getty.sh: ttyHSL1 reserved for CONSOLE
Poky (Yocto Project Reference Distro) 1.7.3 swi-mdm9x28 /dev/ttyHSL1
swi-mdm9x28 login:[/code]
Console_Output.txt (9.72 KB)
