How to get the WP7607 device to work on Linux?
Hi all,
I have some issues about development driver for WP7607 device on Linux, I hope get to a response for my problem.
  • My device supported for 6 interfaces (Modem, ECM,DIAG, NMEA,RMNET0 ), when I plugging device on Linux, Linux kernel was load 3 drivers (qmi_wwan, qcserial, cdc_ether) to manage for 6 interfaces.
    My question:
    1/ Do I need develop drivers for my device ?
    2/ if not needed , with 3 drivers above , Is it fully supported to use my device’s features?
    3/ How can I test the features the driver provides on Linux ?
    So my English writing ability is not good, I’m sorry for that!!
    Thank you for your answer!!!
Here is usb driver in linux
https://source.sierrawireless.com/resources/airprime/software/mbpl/mbpl-software-latest/
You can use minicom to test the AT command port
So do I need to develop drivers for my device?
Do you think wp7606 device will work compatible with those drivers?
Can you compile the driver with your toolchain?
I apologize for my lack of understanding, because this is a completely new field for me, so currently I don’t know how to use the AT command to check.
There is a lot of tutorial in internet
E.g.
Yes, my task is to develop drivers for WP7607, however when I plug it in there are already drivers available, can you give me some advice on what I should do next?
I’m sorry but I don’t understand what you mean. How compile the driver by toolchain?
Did you consult you board vendor how to use the toolchain?
I’m sorry ,I think not yet, because I only received the WP7607 device from my superiors and file PDF has name : AirPrime WP76xx/WP77xx USB Driver Developer’s Guide, but document just mention to interfaces and endpoints of device.
Then i suggest you to connect to ubuntu pc as practice first
Btw, does your supervisor guide you on this?
Yes , it done
Ok
Then you can try minicom on AT command communication
Can you suggest for me some AT command I need try ?
Just type AT and then enter
it show “OK” when I enter AT
Then that means the driver is working
Yes, Can you suggest me what I should do next to use the driver feature?
